    PS4 controller help
    ps4 controller
    2 Posts 2 Posters 191 Views
      tretti
      Pi 3b+
      4.5.1
      Hello. What is the easiest way to go back and forth with a ps4 controller when using it to play the ps4 and then the retropie? I've been having to go through the setup on the retropie every time. Didn't know if there was a simpler way? Thanks.
        There isn't one - basically if you pair it to a device, it will stay paired to that particular device. If you want to move it/connect it to a different device (PC/Pi/PS4), you'll have to do the pairing again.
