    Jedi Power Battles on PCSX-rearmed
    pcsx-rearmedjedi power battcrash
    1 Posts 1 Posters 554 Views
      tacodog
      Are there any know fixes for running Jedi Power Battles on PS1? I'm trying to run this on RetroPie 4.5.1 with PCSX-rearmed using all the default options, and it repeatably crashes very early into the first stage. I did a search and found some old posts, but I didn't see any solutions.
      Thanks,
      runcommand.log:
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Star Wars - Episode I - Jedi Power Battle.m3u" --appendconfig /dev/shm/retroarch.cfg
      Memcard 2: disabled
      Starting PCSX-ReARMed
      Running PCSX Version 1.9 (May 28 2019).
      psxMap: warning: wanted to map @80000000, got 0x6f475000
      Init new dynarec
      testing if we can run recompiled code..
      test passed.
      warning: RAM is not directly mapped, performance will suffer
      Mapped (RAM/scrp/ROM/LUTs/TC):
      77000000/1f800000/1fc00000/08000000/700fa000
      found BIOS file: SCPH7502.BIN
      RGB565 supported, using it
      plugin: plugins/builtin_gpu
      plugin: plugins/builtin_spu
      plugin: plugins/builtin_pad
      Plugins loaded.
      Loaded CD Image: /home/pi/RetroPie/roms/psx/../psx-roms/Star Wars - Episode I - Jedi Power Battle/Star Wars - Episode I - Jedi Power Battle.cue[+cue].
      Track 01 (DATA) - Start 00:02:00, Length 41:59:04
      selected sound output driver: libretro
      CD-ROM Label: SLUS_01046
      CD-ROM ID: SLUS01046
      CD-ROM EXE Name: SLUS_010.46;1
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1006: 28268 Segmentation fault      /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Star Wars - Episode I - Jedi Power Battle.m3u" --appendconfig /dev/shm/retroarch.cfg
