    es_input.cfg wont update; retroarch autoconfigs not created - error saving manually
    gamepadsautoconfigesinput.cfg
    22 Posts 3 Posters 2.7k Views
      mitu Global Moderator @icebear81
      @icebear81 said in es_input.cfg wont update; retroarch autoconfigs not created - error saving manually:
      Im not tracking, was there some fix that was submitted?
      Yes, the scriptmodule has an error when installing on Raspbian Jessie, to which I submitted a correction. But, as @BuZz said - Jessie is not supported and tested anymore, so you should look into migrating your system to a newer release.
      • I
        icebear81
        @mitu Thank you guys! this community is the balls! Really appreciate it - and I try to toss in my nuggets on knowledge learned form pain and learning where I can! -- Appreciate it!
