    Retro-Bit Sega Mega Drive/Genesis 2.4 GHz Wireless Controller incompatible/issues
    controllersemulationstatondevelopmentupdate retropie
    15 Posts 5 Posters 4.8k Views
    • L
      legendos
      Hi @ Devs, all
      I finally got this this new controllers:
      unfortunately they are not recognized as sega mega drive controllers in emulationstation.
      They are recognized as nintendo switch controllers.
      Therefore i cannot use the "home" button as the important hotkey.
      Will there be an workaround for this issue?
      Or an update in the future, that they will be correct recognized?
      Best regards!
        mitu Global Moderator @legendos
        @legendos said in Retro-Bit Sega Mega Drive/Genesis 2.4 GHz Wireless Controller incompatible/issues:
        Why ? Isn't the key registering in EmulationStation ?
        Unless a special driver is released for it, I don't think so.
        Like other controllers that have multiple connection modes, doesn't it have a 'switch mode' button combination that will make it identify (and work) like a non-switch controller ?
        • L
          legendos @mitu
          Thanks for your reply.
          yes, i cannot register the home button. i pushed it again and again, but noting happens.
          No, the sega wireless controller don´t have a switch mode or something like this.
          Shit, i´m about to cry. :(
          mituM RionR 2 Replies Last reply Reply Quote 0
            They don't seem to. According to their support manual, the Home button works only on macOS and Nintendo Switch and it also has some configuration, but no explicit 'switch mode' instructions :
            • PC / ANDROID®
              The controller’s LED indicates the input mode it is in. To switch between the modes, press and hold Start + B until it changes color.
              » Red indicates it is in D-Input mode.
              » Blue indicates it is in X-Input mode.
            • RionR
              Rion @legendos
              @legendos Have you paired it in d-input mode?
              Manual for SEGA® Mega Drive 8-Button Arcade Pad - 2.4 GHz Wireless
              Support page with manual link directly.
              Edit: After closer inspection the Home button is only avaliable in Mac and Switch mode.
              @mitu Looks like we answered the same question minutes apart 😊
              FBNeo rom filtering
              Mame2003 Arcade Bezels
              Fba Arcade Bezels
              Fba NeoGeo Bezels
              mituM 1 Reply Last reply Reply Quote 1
                mitu Global Moderator @Rion
                @Rion said in Retro-Bit Sega Mega Drive/Genesis 2.4 GHz Wireless Controller incompatible/issues:
                Heh. On the other hand, since the controller identifies as a Switch, the Home should be activated.
                @legendos can you try to see if the button is detected by jstest ?
                Exit EmulationStation, then run jstest /dev/input/js0 (make sure said controller is the only one active/plugged in). Press buttons/pads and see if they register - including the Home button. Exit the test with Ctrl + C, start back EmulationStation by typing emulationstation.
                L 2 Replies Last reply Reply Quote 0
                • L
                  legendos @mitu
                  Ok, i test it soon!
                  then I'll let you know if it works!
                  • L
                    legendos @mitu
                    Thank you so much!
                    after i entetred "jstest /dev/input/js0", i was able to push every button on the controller inclusive the magic "home" button!
                    After that, i restartet the system.
                    Emulationstation detected the controller as a new one (second gamepad) called "xbox 360 gamepad".
                    At this point, i was able to register every button (inclusive) the "home" button!
                    But why did recognize emu.station my controller as an xbox 360 gamepad?
                    Is now an Update (from the devs) possible to recognize it as what it is?
                    Thanks again! :))))
                    Best Regards!
                      No, there hasn't been any update that would fix this. More likely the controller started in PC mode (D-Input/X-input ?) and the key is enabled.
                      Try testing it a few more times - maybe the order of start-up (Pi first, controller 2nd or the other way around) has an impact on how the contoller identifies itself.
                      • RionR
                        Rion @mitu
                        As @mitu mentioned before.
                        So in other words. Try to start the controller in X-Input mode "Blue led"
                        FBNeo rom filtering
                        Fba Arcade Bezels
                        Fba NeoGeo Bezels
                        • L
                          legendos @Rion
                          @Rion
                          Yes, your right.
                          I don't know thus until now.
                          Thank you!
                          I think this topic can marked as "solved" and be closed.
                            penx
                            I have the bluetooth version of this controller and have the same issue - I can map every key other than the home button.
                            When I hold down the home button in 'Controller Input' it shows it as 'Keyboard'.
                            If I try using jstest as described above, it appends "^@" to the end of the line but nothing else.
                            Any ideas?
                            I've raised an issue here https://github.com/Aloshi/EmulationStation/issues/838
                            mituM CrushC 2 Replies Last reply Reply Quote 0
                              mitu Global Moderator @penx
                              This means that button is acting as a keyboard button.
                              Any ideas?
                              Start the gamepad in a different 'mode' and see if the button is recognized as a gamepad input.
                              RetroPie doesn't use the original EmulationStation, it has its own fork (https://github.com/RetroPie/EmulationStation). The upstream project is not so active anymore and your issue is not an EmulationStation problem, so I don't expect you'll be getting any update.
                              • CrushC
                                Crush @penx
                                In my experience in D-Input mode the Home button has never worked on Retropie but all the other buttons work, thus you can set the Hotkey to select.
                                In X-Input mode the Home button works, but for whatever reason the C, Z and perhaps L1 button do not work.
                                  penx @mitu
                                  @mitu said in Retro-Bit Sega Mega Drive/Genesis 2.4 GHz Wireless Controller incompatible/issues:
                                  I have found 6 different wireless modes:
                                  Key Mode LEDs
                                  Y Switch Strobe
                                  X Mac 3,4
                                  Z ? 2,3
                                  A Android 1
                                  B D-Input 3
                                  C ? 1,3
                                  Switch pairs and is recognised as a controller in configure input, but holding down a button doesn't do anything, so I can't bind anything.
                                  Mac mode, holding down home shows 'keyboard' but when I go in to key binding it lets me bind the home button. It doesn't let me bind the Z and C buttons.
                                  Z,A,B,C mode all have the same issue with the home button as described above.
                                  There is a wired X-Input mode (LED 2) which allows me to bind all buttons but I can't figure out if there's a wireless version of this.
                                  There is a wired PS3 mode which also allows me to bind all buttons, but I also can't figure out how to get it to pair wirelessly in this mode.
                                  Is there no way to manually bind whatever keyboard button it thinks it is?
                                  Is this a bug with anything else, or a fundamental issue with the hardware?
