    Help with My Raspberry Pi 4
    raspberry pi 4sd imagearcade retropie
    28 Posts 14 Posters 3.2k Views
      mat
      Thanks, and I was reading the thread over on reddit and some mentioned USB firmware/rom service? Is this something I need to do? My RP4 is when it was first released, so no firmware updates have been done to it.
        mitu Global Moderator @mat
        You may be referring to the rpi-eeprom update service. This is now part of the default OS and it runs at boot to check if an update to the boot EEPROM or the USB controller firmware is needed, downloading and preparing the update on the next restart.
        As long as you update the OS normally, this is installed and configured automatically.
          mat
          I never updated the OS on RP3, but I did run "update all installed packages" every now and then so from the reddit thread, I guess that would update the OS too?
            @mat said in Help with My Raspberry Pi 4:
            Yes.
            • V
              Vitor Ferreira @djchewmacca
              @djchewmacca Is it just donwloading the most recent build and following the normal process? Thanks
              • W
                wmcclelion @djchewmacca
                @djchewmacca Are there change logs or release notes for the weekly builds so we can see the changes from one to the next?
                  BuZz administrators @wmcclelion
                  @wmcclelion they are automated but all code changes are on GitHub. Please use this forum for reporting issues first though.
                  https://github.com/RetroPie/RetroPie-Setup/commits/master
                  W 1 Reply Last reply Reply Quote 1
                  • W
                    wmcclelion @BuZz
                    @BuZz Thank you sir. That helps a lot.
