    lr-atari800 not starting after updating from 4.5.1
    lr-atari800brokenretroarch8005200
    34 Posts 6 Posters 4.9k Views
      mitu Global Moderator @GeekOB
      @GeekOB Thanks. I've fixed the error you reported, but there's a new error related to the - other - changes added in RetroArch, this time a dependency issue which requires disabling the FFMPEG core. I'll see what can be done.
      GeekOBG 1 Reply Last reply Reply Quote 0
      • GeekOBG
        GeekOB @mitu
        What's the downside of disabling the FFMPEG core @mitu ?
          BuZz administrators @GeekOB
          @GeekOB no screen recording.
          • GeekOBG
            GeekOB @BuZz
            Thanks @BuZz
            I don't use this feature at all @mitu, happy to disable and test further if required.
              @GeekOB I've disabled ffmpeg just for testing on my branch - you can re-fetch using the instruction I posted yesterday the RetroArch 1.8.3 branch and try re-installing retroarch from source.
              Regarding the ffmpeg library usage in RA, I think it may be a source code bug, since the checks for ffmpeg all yield a positive result (so version seems ok), but compilation doesn't work (with the error you got).
                showstopper
                Is the lr-atari800 core still at 3.1.0 for retroarch? I play 5200 because it has a high pitch noise which apparently is fixed in version 4.
                  mitu Global Moderator @showstopper
                  @showstopper The Libretro atari800 core hasn't been updated to 4.x (now 4.2.0), it's still at the same version. The bug you mention I think it's already reported, we might patch it locally until upstream includes the fix.
                  • GeekOBG
                    GeekOB @mitu
                    Hi @mitu and @BuZz ,
                    I can confirm the lr-atari800 core works properly with RetroArch 1.8.3, both on the Atari 5200 and 8-bit systems. I'm going through all the other cores looking for issues, so far everything seems to be running smoothly.
                    Is there any particular scenario you'd like me to test?
                      @GeekOB said in lr-atari800 not starting after updating from 4.5.1:
                      Thank you for testing.
                      Well, if you have overlays - test them and see if you have any problems with it.
                      Otherwise, just use it normally and see if anything pops up that might look like a bug. Some of the menu options have changed; I think some menu entries are renamed or just appear conditionally (depending on the build options) so that's something which you can expect.
                      • GeekOBG
                        GeekOB @mitu
                        So far so good @mitu. All cores I've been able to test so far run great with and without overlays and shaders, I noticed that RetroArch is being updated to 1.8.4 from source so your testing must have shown the same :)
                        (can I now safely revert back to the normal RetroPie repo then?)
                          Sure, reverting will not delete your already installed version.
                          • I
                            icode
                            I am a similar problem where i get runcommand segmentation fault, but I am able to get lr-800 to work if I select the game but press a Key to get the menu before it auto-launches. From the menu I select launch and quickly hold down F1 and it will get into the 800 emulator and I can load the game from there. I hope this is the same problem and they will fix it soon.
                              mahalingam @icode
                              @icode I just did a fresh install of 4.6 on a Pi 3B+ and I'm seeing the same issue. In some cases I am able to hit F1 and get to the lr-atari800 emulator menu before it segfaults; from there I can load a game and it works fine, but navigating the menus is a bit of a pain. Just for snicks I put a fresh install of Lakka on another SD card and BOOM! everything works perfectly right out of the box. Hopefully the next RetroPie release will fix this problem so I can switch back.
                              BuZzB 1 Reply Last reply Reply Quote 1
                                BuZz administrators @mahalingam
                                @mahalingam it was fixed, so if you're getting the issue open a new topic with some info.
                                • A A1eg referenced this topic on
