    Problems with raspberry pi 3B+ AFTER UPDATE
    raspberrypi 3b+gameboy1upxlcharghdmi issuefan
    7 Posts 5 Posters 942 Views
    • I
      ifailflash
      I bought a Gameboy 1up Xl recently with a raspberry pi 3b+ and it was working fine until I decided to connect it to wifi and update. With this, some problems appeared:
      • the fan goes louder on startup, then it fades to normal (not really a problem but it didn't happen when it arrived)
      • I can't seem to charge it, it has 4 lights indicating battery but, while charging, it doesn't go past the second light (I can't say if this is only visual or if it isn't charging, which is weird because it was charging fine before the update)
      • when plugging it through HDMI to the TV, the screen goes blue and starts flickering, but no image shows ( again, this is weird because it was working fine)
      Anything I can do to reverse this to factory/fix this?
      My programming skills are pretty much non existent, so if there's a way to fix this within the Raspberry's software, that'd be great
      Thanks!
        dankcushions Global Moderator @ifailflash
        @ifailflash so i take it this was a pre-installed third party build + image? i'm afraid we don't support those.
        can your seller not assist? presumably they could point you in the direction of the image they use.
        • sirhenrythe5thS
          sirhenrythe5th
          Another proof for "never change a running system"!
          IMO: at least when i bought a premade system and i know absolutly nothing about its content...i would never dare to update anything!!!
          Concerning "ask the seller": a new way of business seems to be born: i have seen some offers lately that the sellers / creators "will answer questions for $20".
          RetroRatio: 1.91
          Started Games beaten: 2,40%
          simpleethatS I 2 Replies Last reply Reply Quote 0
          • simpleethatS
            simpleethat @sirhenrythe5th
            "I sold you this thing that only sort of works, give me more money and I might be able to sort of fix it."
            • I
              ifailflash @dankcushions
              @dankcushions I sent the same message, figured in here would get a faster answer, but sorry, didn't meant to break any of the rules
              • I
                ifailflash @sirhenrythe5th
                @sirhenrythe5th Well, I never thought updating would make it work in a different way, I mean, I assumed it was code fixing and that kind of stuff
                  BuZz administrators @ifailflash
                  @ifailflash It was probably customised in a way that was not safe to update. Impossible to know as we didn't make it.
