    Is it possible to output to both HDMI and another display?
    dual display
    5 Posts 2 Posters 711 Views
    • V
      VictimRLSH
      I know the Pi 4 can do 2 HDMI displays and clone the output to the 2nd one, but can a 3 B send the same output to both HDMI and a Pimoroni Hyperpixel 4.0 at the same time?
      I found a relatively easy way to switch between them on a reboot, which might do, but having both could be nice. https://forums.pimoroni.com/t/hyperpixel-selective-output-eg-on-boot/5193
      System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
      • IceChes1I
        IceChes1
        Maybe there's such thing as an HDMI splitter?
        HOME CONSOLE
        Pi 4
        SanDisk 64 GB
        Master branch install
        3.5 amp CanaKit PSU
        Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
        HANDHELD
        Pi 0 W
        SanDisk 32 GB
        Random image I found. Had a driver I needed.
        IPEGA PG-9157 USB Receiver
        • V
          VictimRLSH @IceChes1
          @IceChes1 There is. It will allow you to view an HDMI output on 2 monitors. I want to view HDMI output and a display on the GPIO pins simultaneously. I'm thinking it can't be done, but we'll see.
          • IceChes1I
            IceChes1
            Is that possible?
            HOME CONSOLE
            Pi 4
            SanDisk 64 GB
            3.5 amp CanaKit PSU
            HANDHELD
            Pi 0 W
            SanDisk 32 GB
            • V
              VictimRLSH
              Not looking like it from what I can find, I'll have to go with the autodetect on boot script, that will have to be good enough.
