    Scraper help
    skyscraperselph scraperthegamesdbscreenscraperes help
    15 Posts 9 Posters 1.3k Views
    • IceChes1I
      IceChes1
      What about Skyscraper/Selph Scraper? Anyone know what to do for those?
      HOME CONSOLE
      Pi 4
      SanDisk 64 GB
      Master branch install
      3.5 amp CanaKit PSU
      Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
      HANDHELD
      Pi 0 W
      SanDisk 32 GB
      Random image I found. Had a driver I needed.
      IPEGA PG-9157 USB Receiver
        Clyde @IceChes1
        @IceChes1 What do you mean by "to do for those"? If screenscraper.fr has problems, all scrapers are affected. Apart from that, their usage is explained in https://retropie.org.uk/docs/Scraper/.
        If you have problems or explicit questions about them after reading those instructions, ask away, but please be more specific.
        nightbirdmediaN 1 Reply Last reply Reply Quote 0
        • nightbirdmediaN
          nightbirdmedia @Clyde
          @Clyde I think he means how to get them to work. They kept asking me to register when I attempted to use them. But how do you register for them? I tried to register at https://www.screenscraper.fr but it wouldn't send me a confirmation email.
          • N
            nick1984
            I scraped all my systems, for covers and video samples and I fount in many systems that most of ROMS appears 2 3 or 4 times in the ROM lists. They were not copied (I checked with Filezilla) but I see more than one in the game list.
            Pi Model or other hardware: raspberry pi 3 b+
            RetroPie Version Used: 4.1
              AlienUA
              You can install skyscraper and register on http://screenscraper.fr/
              Then add your creds into
              sudo nano /opt/retropie/configs/all/skyscraper/config.ini
              in end fo file add
              [screenscraper]
              userCreds="user:pass"
              use skyscraper, it works for me.
              saccublendaS 1 Reply Last reply Reply Quote 0
              • saccublendaS
                saccublenda @AlienUA
                Is it possible to use screenscraper.fr credentials in the Emulationstation's internal scraper?
                  mitu Global Moderator @saccublenda
                  @saccublenda said in Scraper help:
                  No, that's not supported.
                    AlienUA @mitu
                    @saccublenda Sorry, I didn't check this.
                      Clyde @nightbirdmedia
                      @nightbirdmedia You don't have to register at screenscraper.fr, but they'll close the access for non-registered users if their servers are under heavy load – like at the moment, as I just checked. You can see their server status on their website.
                      More access will be granted to monthly paying subscribers. A mere 1€ per month will get you access even if the access for registered (non-paying) users is closed, as well as 50.000 scrapes per day instead of only 20.000.
                      See their website for this and more information.
                      nightbirdmediaN 1 Reply Last reply Reply Quote 1
                      • nightbirdmediaN
                        @Clyde thanks.
