    SOLVED: rpi4/retropie weekly build scummvm vs lr-scummvm slow graphics
    rpi4scummvmlr-scummvm
    7 Posts 3 Posters 850 Views
      mth75
      Hi all,
      While building a Rpi4/Retropie build in a C= Plus 4 case I installed the weekly build of the Rpi4/RetroPie build. As already known, most emu's run quite good.
      I noticed however that ScummVM, both the binary or a fresher master GitHub source compile/install run games quite slow. While troubleshooting I also installed lr-scummvm ... much to my suprise, lr-scummvm runs without graphic slowdowns.
      The question is, is it possible to compile scummvm against the new graphic layer of the RPI4/Retropie build, since this seem to be the problem?
      Best,
      Marc!
        @mth75 said in rpi4/retropie weekly build scummvm vs lr-scummvm slow graphics:
        If you're running ScummVM on your PI4, the emulator is already using the 'new graphic layer'. What game(s) are you trying out ?
          mth75 @mitu
          @mitu For example, Full Throttle, DOTT, Broken Sword, Gabriel Knight 1, 2, Voyeur, they suffer from stuttering graphics.
            BuZz administrators
            It's probably the sdl2 vsync issue. Check if there's a vsync option in scummvm. But note rpi4 is still in development - we are not even really ready for bug reports yet.
              mth75 @BuZz
              @BuZz said in rpi4/retropie weekly build scummvm vs lr-scummvm slow graphics:
              Thx! I will check. I understand that thing are still in development, but I must say, progress is great.
                mth75
                I reinstalled Scummvm (compiled from source: master) with the automatic sdl2 update:
                https://github.com/RetroPie/RetroPie-Setup/commit/7c74cff0cf47306f8bdec2c4bb1c6af221a5fbb6
                with vsync fix ... all seems good know. Thanks for the quick change ...
                  mth75 @mth75
                  Also see the related:
                  https://retropie.org.uk/forum/topic/24689/frameskip-issues-on-pi4
