    Help organizing my FinalBurn Neo Roms. I'm a Newb
    organizationfinal burn alphhelp mame roms
    9 Posts 4 Posters 3.3k Views
      Rookerman
      Hey there. Firstly, thank you for clicking to see if you're able to help..
      I'm really good at windows based stuff, but Raspbian and Retropie is Brand new to me. I've looked only on how to do this, but can't really find an easy clear answer.
      I have tons of dublicate games and games I don't care for to show up. How do I remove the dups, and fake games? I saw soething about .dat files.
      • IceChes1I
        IceChes1
        How did you get these ROMs?
        Put the SD into your Windows computer and delete the duplicates in rootfs/home/pi/Retropie/roms/fbneo.
        HOME CONSOLE
        Pi 4
        SanDisk 64 GB
        Master branch install
        3.5 amp CanaKit PSU
        Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
        HANDHELD
        Pi 0 W
        SanDisk 32 GB
        Random image I found. Had a driver I needed.
        IPEGA PG-9157 USB Receiver
          Rookerman
          I got a rom pack for FBneo. I read online that you need all the roms for them to work properly.
          • IceChes1I
            IceChes1
            @Rookerman said in Help organizing my FinalBurn Neo Roms. I'm a Newb:
            I do not think this is true.
            HOME CONSOLE
            Pi 4
            SanDisk 64 GB
            3.5 amp CanaKit PSU
            HANDHELD
            Pi 0 W
            SanDisk 32 GB
              Rookerman @IceChes1
              @IceChes1
              Like there are parent roms, and child roms. Some Roms need the Parent Roms to work..
              • IceChes1I
                IceChes1
                Dunno. I have no idea how to help you then...
                HOME CONSOLE
                Pi 4
                SanDisk 64 GB
                3.5 amp CanaKit PSU
                HANDHELD
                Pi 0 W
                SanDisk 32 GB
                  mitu Global Moderator @Rookerman
                  @Rookerman Take a look at https://retropie.org.uk/docs/Validating,-Rebuilding,-and-Filtering-ROM-Collections/, will give you an idea how to organize your ROM collection.
                  If your set is un-merged, then each ROM can be used standalone, so you can copy only the games you want to the arcade/fba folders. Otherwise you can organize your collection and create un-merged set, so you don't have to copy the whole set to your PI.
                  @IceChes1 your answers are off the mark and you clearly don't know enough to give a constructive answer in the topic.
                  • IceChes1I
                    IceChes1
                    @mitu said in Help organizing my FinalBurn Neo Roms. I'm a Newb:
                    No, I do not know enough. I have never used FinalBurnNeo and thought that the skills I learned from MAME would be enough. Won't reply here again.
                    HOME CONSOLE
                    Pi 4
                    SanDisk 64 GB
                    3.5 amp CanaKit PSU
                    HANDHELD
                    Pi 0 W
                    SanDisk 32 GB
                      dankcushions Global Moderator @IceChes1
                      @IceChes1 said in Help organizing my FinalBurn Neo Roms. I'm a Newb:
                      fyi MAME also has the concept of non-merged sets. see https://github.com/RetroPie/RetroPie-Setup/wiki/Validating,-Rebuilding,-and-Filtering-ROM-Collections#crash-course-in-arcade-rom-terminology
