    custom USB controller not recognized
    controllerusbraspbian
    3 Posts 2 Posters 335 Views
      kfairchild6
      I have an Atari joystick modified to send serial signals through a Feather nRF52 board from Adafruit; it uses a CP2104 UART bridge connected to a USB port. The signals work fine when connected to my Windows PC, so they're being sent correctly. I can't get my RetroPie to recognize the USB "custom controller". Checking lsusb shows the device (005):
      pi@retropie:~ $ lsusb
      Bus 001 Device 006: ID 050d:0803 Belkin Components Nostromo 1745 GamePad
      Bus 001 Device 005: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
      Bus 001 Device 004: ID 04d9:2ba0 Holtek Semiconductor, Inc.
      Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
      Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      But all that appears in /dev/input are my keyboard/mouse unit and gamepad:
      pi@retropie:~ $ ll /dev/input/by-id
      total 0
      0 lrwxrwxrwx 1 root root 9 Feb  2 12:05 usb-04d9_USB_Keyboard-event-kbd -> ../event0
      0 lrwxrwxrwx 1 root root 9 Feb  2 12:05 usb-04d9_USB_Keyboard-if01-event-mouse -> ../event1
      0 lrwxrwxrwx 1 root root 9 Feb  2 12:05 usb-04d9_USB_Keyboard-if01-mouse -> ../mouse0
      0 lrwxrwxrwx 1 root root 9 Feb  2 12:05 usb-Nostromo_Nostromo_n45_Dual_Analog_Gamepad-event-joystick -> ../event2
      0 lrwxrwxrwx 1 root root 6 Feb  2 12:05 usb-Nostromo_Nostromo_n45_Dual_Analog_Gamepad-joystick -> ../js0
      section from dmesg that might be useful:
      [    2.661680] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
      [    2.796330] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60
      [    2.796349] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    2.796361] usb 1-1.4: Product: CP2104 USB to UART Bridge Controller
      [    2.796369] usb 1-1.4: Manufacturer: Silicon Labs
      [    2.796377] usb 1-1.4: SerialNumber: 018C5E43
      [    2.891560] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
      [    3.044978] usb 1-1.5: New USB device found, idVendor=050d, idProduct=0803
      [    3.045001] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    3.045011] usb 1-1.5: Product: Nostromo n45 Dual Analog Gamepad
      [    3.045020] usb 1-1.5: Manufacturer: Nostromo
      [    3.061834] input: Nostromo Nostromo n45 Dual Analog Gamepad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:050D:0803.0003/input/input2
      [    3.062094] hid-generic 0003:050D:0803.0003: input,hidraw2: USB HID v1.10 Gamepad [Nostromo Nostromo n45 Dual Analog Gamepad] on usb-3f980000.usb-1.5/input0
      [    3.080073] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    3.224936] systemd-journald[100]: Received request to flush runtime journal from PID 1
      [    3.852753] usbcore: registered new interface driver usbserial
      [    3.852830] usbcore: registered new interface driver usbserial_generic
      [    3.852886] usbserial: USB Serial support registered for generic
      [    3.862885] usbcore: registered new interface driver cp210x
      [    3.862960] usbserial: USB Serial support registered for cp210x
      [    3.863145] cp210x 1-1.4:1.0: cp210x converter detected
      [    3.879077] usb 1-1.4: cp210x converter now attached to ttyUSB0
      Pi 3B+, Linux retropie 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l
      When trying "Configure Input" within Emulation Station, only the Gamepad is detected. Can anyone help me get the Pi to "see" this USB device as a HID? Thanks for any help you can provide!
        You device is detected, using its driver, as a serial adapter. In order to function as a HID, you'd need an additional driver that translates the serial data to gamepad/joystick actions.
        Note that the original Atari joystick, while it used a DB9 pinout, did not use a serial protocol.
        Maybe inputattach can translate the serial protocol to HID events, try to see if it works with the joysticks supported.
          kfairchild6
          Thanks, that's the kind of thing I'm looking for. I'll check it out.
