    Golden Tee Fore and CHD/Eagle BIOS issues....other CHDs have worked for me fine.
    golden teechdchd fileseaglebios file
    27 Posts 7 Posters 5.1k Views
    • stoney66S
      stoney66
      @sssetz what about older versions of gtfore! like 2002 (gtfore02.zip) and 2003 (gtfore03.zip). They all use the same bios file, just need the diff rom/chd.
        sssetz @stoney66
        @stoney66 said in Golden Tee Fore and CHD/Eagle BIOS issues....other CHDs have worked for me fine.:
        I have tried those and all give the same result unfortunately...
          sssetz @arcadez2003
          @arcadez2003 said in Golden Tee Fore and CHD/Eagle BIOS issues....other CHDs have worked for me fine.:
          g4c-us-u.u53
          Thanks for this in depth response, but are you saying I should just try to use the gtfore01.zip and gtfore01 CHD files and see if that will work? Or somehow rename them for use with the gtfore06 CHD? Or are you saying look for different CHD files? As far as I can tell rom zip files are basically empty directory folders for games like GTFore, is that right?
          Ive tried gtfore01 and gtfore02 (with their respective CHDs in a folder named after the rom) and they wont work either.....
          lostlessL arcadez2003A 2 Replies Last reply Reply Quote 0
          • lostlessL
            lostless @sssetz
            @sssetz you need to make sure you have the right rom and chd version for the version of MAME you are using. Trying to mix and match from any roms randomly found on the internet will lead to frustration.
            • arcadez2003A
              arcadez2003 @sssetz
              @sssetz I was saying just try another version of the game you dont need to mix and match anything, but from what your saying you've done that already.
              Maybe it's your setup that's causing the issue a video or sound setting in your frontend.?? as i just googled golden tee fore Rpi and it seems plenty of
              users have this game up and running.
              Arcade Addict
                sssetz
                Just an update about a week out of talking on this thread, no luck. But I was able to find someone who had a confirmed CHD/iteagle file that is working for their RPi/Retropie and still no luck for myself, so not really sure. Maybe the iteagle needs to have some certain setup I am missing, cause I definitely have got other CHD games to work.....regardless thx for everyones help.
                  AlCzervik @sssetz
                  @sssetz Thanks for the updates! Any luck since? Also, you said in your last post someone confirming they had it working for their RPi. What version? 4 I assuming?
