    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 27.6k Views
    • E
      escc1986
      @ExarKunIv said in ScummVM Controlller Issues:
      if [ "$1" = "scummvm" ]
      then
      sudo killall > /dev/null 2>&1 xboxdrv
      sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1
      --evdev /dev/input/event0
      --silent
      --detach-kernel-driver
      --force-feedback
      --mimic-xpad
      --trigger-as-button
      --evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y
      --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_TL2=back,BTN_TR2=start
      --ui-axismap dpad_x=REL_X:10,dpad_y=REL_Y:10
      --ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC
      --ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,
      fi
      let me test it .... lets see .. fingers crossed
      • E
        escc1986
        unfortunately it did not work
        dPad was not working
        • ExarKunIvE
          ExarKunIv @escc1986
          @escc1986
          dang, well im working on getting my drivers up and going again, till then i dont have much else i can offer.
          , but ill keep digging a very long guide
          https://retropie.org.uk/forum/topic/2861/guide-advanced-controller-mappings/133?_=1581437532429
          • E
            escc1986
            im sorry to be a big bother ... i apprecite the help .. its ok i will wai for as long as you could get your drivers up ...
            something is overiding the controllers possiblty
            i just changed my start key assainged to my B button
            and changed my A key assigned it to my space key ...
            no matte what changes and combonations
            my controller
            L = f5
            R = space
            i know the biggest issue is the dpad .... but any idea ...
            • ExarKunIvE
              ExarKunIv @escc1986
              @escc1986
              post what you changed
              • E
                escc1986
                #!/bin/sh
                then
                sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
                        --evdev /dev/input/event0 \
                        --silent \
                        --detach-kernel-driver \
                        --force-feedback \
                        --mimic-xpad \
                        --trigger-as-button \
                        --evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                        --evdev-keymap BTN_TL2=a,BTN_TR2=b,BTN_[•]=x,BTN_[•]=y,BTN_WEST=lb,BTN_Z=rb,BTN_EAST=back,BTN_SOUTH=start /
                        --ui-axismap dpad_x=REL_X:10,dpad_y=REL_Y:10 \
                        --ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
                        --ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void, \
                fi
                • E
                  escc1986
                  @escc1986 said in ScummVM Controlller Issues:
                  • ExarKunIvE
                    ExarKunIv @escc1986
                    @escc1986
                    ok this might be a pain for you, and im sorry.
                    but wipe everything out of the runcommmand.
                    save it in a txt file of course.
                    i want to see if there is something overriding what we are trying to do, cuz what you posted should of changed when you changed the mapping
                    also you have xboxdrv installed
                    reboot after you wiped the file
                    • E
                      escc1986
                      ok sure
                      no problem
                      will let you know when done
                      • E
                        escc1986
                        #!/bin/sh
                        then
                        sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
                        sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 \
                        --silent
                        --force-feedback
                        --deadzone-trigger 15%
                        --deadzone 4000
                        --mimic-xpad
                        --dpad-only
                        --ui-axismap lt=void,rt=void
                        --ui-buttonmap a=BTN_EAST,b=BTN_SOUTH,start=KEY_F5,back=KEY_ESC \
                        f1
                         omxplayer -b "/home/pi/video/intro.mp4" > /dev/null &
                        # the line below is needed to use the joystick selection by name method
                        bash "/opt/retropie/supplementary/joystick-selection/js-onstart.sh" "$@"
                        [[ $2 == openbor ]] && filename=$(basename "$3") && cp "/opt/retropie/ports/openbor/Saves/master.cfg" "/opt/retropie/ports/openbor/Sav$
                        • E
                          escc1986
                          ok
                          wiped the runcommand
                          rebooted
                          now what would you like me to do
                          • ExarKunIvE
                            ExarKunIv @escc1986
                            @escc1986
                            start scrumm get in a game and see if the controller does anything like before
                            it should not do athing not even the triggers with f5 and space
                            • E
                              escc1986
                              just tested now
                              same
                              R - f5
                              L- space
                              so what is taking over
                              i have xboxdrv installed
                              https://dropmefiles.com/UgoPt
                              • E
                                escc1986
                                perhaps ... do you need me to send you any config files in my pi ?
                                • ExarKunIvE
                                  ExarKunIv @escc1986
                                  @escc1986
                                  no clue.
                                  at with what you showed me. those keys should not do anything.
                                  unless our setup is not working and those are just set up from the devs of scumm
                                  so since you have nothing in the run command
                                  we can do a different way of testing
                                  with a game running
                                  put this in putty
                                  /opt/retropie/supplementary/xboxdrv/bin/xboxdrv \
                                  	--silent \
                                  	--force-feedback \
                                  	--mimic-xpad \
                                      --evdev-keymap KEY_#305=a,KEY_#304=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#314=back,KEY_#315=start \
                                  	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
                                  	--ui-axismap x2=void
                                  this a shortcut on testing
                                  • E
                                    escc1986
                                    --silent
                                    --force-feedback
                                    --mimic-xpad
                                    --trigger-as-button
                                    xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
                                    Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
                                    Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
                                    This program comes with ABSOLUTELY NO WARRANTY.
                                    This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details.
                                    -- [ ERROR ] ------------------------------------------------------
                                    Error: No stuitable uinput device found, tried:
                                      /dev/input/uinput: No such file or directory
                                      /dev/uinput: Permission denied
                                      /dev/misc/uinput: No such file or directory
                                    Troubleshooting:
                                      * make sure uinput kernel module is loaded
                                      * make sure joydev kernel module is loaded
                                      * make sure you have permissions to access the uinput device
                                      * start the driver with ./xboxdrv -v --no-uinput to see if the driver itself works
                                    • ExarKunIvE
                                      ExarKunIv @escc1986
                                      @escc1986
                                      ok that is what im getting too.
                                      i think we need some more help on this
                                      i just hope he is still coming here
                                      • E
                                        escc1986
                                        hope we may get the help on here
                                        hope its a simple fix
                                        im sorry for the trouble ,
                                        hummm i wonder , whats wrong
                                        • ExarKunIvE
                                          ExarKunIv @escc1986
                                          @escc1986 no trouble, im having the same thing so its a problem for me too
                                          • E
                                            escc1986
                                            hope we may get the hep :)
