    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 27.6k Views
    • ExarKunIvE
      ExarKunIv @escc1986
      @escc1986
      ugh.... i cant belive i did that i forgot a command
      	--evdev /dev/input/event0 \
      	--silent \
      	--detach-kernel-driver \
      	--force-feedback \
      	--mimic-xpad \
      	--trigger-as-button \
      	--evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
          --evdev-keymap KEY_#305=a,KEY_#304=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#314=back,KEY_#315=start \
      	--ui-axismap dpad_x=REL_X:10,dpad_y=REL_Y:10 \
      	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
      	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
      	--ui-axismap x2=void
      try this
      • E
        escc1986
        do i add
        #!/bin/sh
        if [ "$1" = "scummvm" ]
        then
        sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
        • ExarKunIvE
          ExarKunIv @escc1986
          @escc1986
          no not yet
          run what i posted just now in putty when a game is running and see what the buttons do.
          i guess i needed a refresher on this
          • E
            escc1986
            @ExarKunIv said in ScummVM Controlller Issues:
            --silent
            --force-feedback
            --mimic-xpad
            --trigger-as-button
            xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
            Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
            Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
            This program comes with ABSOLUTELY NO WARRANTY.
            This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details.
            Your Xbox/Xbox360 controller should now be available as:
              /dev/input/js1
              /dev/input/event1
            Press Ctrl-C to quit
            • E
              escc1986
              interesting ....
              dpad works -moves mouse
              A button works - left mouse click
              b button works - right mouse click
              L - not working
              R - not working
              Select not working
              Start not workings
              its good to see the mouse works and the 2 buttons
              very nice !!!!!
              ExarKunIvE 2 Replies Last reply Reply Quote 0
              • ExarKunIvE
                ExarKunIv @escc1986
                @escc1986 sweet
                now we are getting somewhere
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986
                  what buttons do you want to do what
                  • E
                    escc1986
                    B = left click
                    A = Right click
                    Start = space bar
                    Select - f5
                    please .... Thank you
                    • ExarKunIvE
                      ExarKunIv @escc1986
                      @escc1986
                      ok
                      run
                      evtest /dev/input/event0
                      press the start and select to test them
                      post what you get
                      • E
                        escc1986
                        Event: time 1581450539.384302, type 4 (EV_MSC), code 4 (MSC_SCAN), value 9000a
                        Event: time 1581450539.384302, type 1 (EV_KEY), code 313 (BTN_TR2), value 1
                        Event: time 1581450539.384302, -------------- SYN_REPORT ------------
                        Event: time 1581450539.579279, type 4 (EV_MSC), code 4 (MSC_SCAN), value 9000a
                        Event: time 1581450539.579279, type 1 (EV_KEY), code 313 (BTN_TR2), value 0
                        Event: time 1581450539.579279, -------------- SYN_REPORT ------------
                        Event: time 1581450540.749286, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90009
                        Event: time 1581450540.749286, type 1 (EV_KEY), code 312 (BTN_TL2), value 1
                        Event: time 1581450540.749286, -------------- SYN_REPORT ------------
                        Event: time 1581450540.959255, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90009
                        Event: time 1581450540.959255, type 1 (EV_KEY), code 312 (BTN_TL2), value 0
                        Event: time 1581450540.959255, -------------- SYN_REPORT ------------
                        start is = tr2
                        select is = tl2
                        • ExarKunIvE
                          ExarKunIv @escc1986
                          @escc1986
                          run this
                          	--silent \
                          	--force-feedback \
                          	--mimic-xpad \
                              --evdev-keymap KEY_#305=a,KEY_#304=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#312=select,KEY_#313=start \
                          	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,select=KEY_F5,start=KEY_SPACE \
                          • E
                            escc1986
                            --silent
                            --force-feedback
                            --mimic-xpad
                            --trigger-as-button
                            Works good :)
                            • ExarKunIvE
                              ExarKunIv @escc1986
                              @escc1986
                              good
                              so you have both a runcommd-onstart and a runcommad-onend file made correct
                              • E
                                escc1986
                                i belive so
                                how may i check
                                • ExarKunIvE
                                  ExarKunIv @escc1986
                                  @escc1986
                                  well i know you have the runcommand-onstart i saw the vid
                                  put this in the runcommand-onstart
                                  #!/bin/sh
                                  then
                                  sudo killall > /dev/null 2>&1 xboxdrv
                                  sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
                                  --silent
                                  --force-feedback
                                  --mimic-xpad
                                  --trigger-as-button
                                  fi
                                  • E
                                    escc1986
                                    ok , i pasted in runcommand-onstart and rebooted my device
                                    just tested it
                                    appears as same as before , dpad not working and L is space & R is f5
                                    • ExarKunIvE
                                      ExarKunIv @escc1986
                                      @escc1986
                                      ok so the problem now is getting the game and the script we just made to work together.
                                      • E
                                        escc1986
                                        humm interesting , i wonder why they dont work together
                                        • ExarKunIvE
                                          ExarKunIv @escc1986
                                          @escc1986
                                          they do
                                          you just need everything on the same page.
                                          IE
                                          correct drivers turned on, correct names ETC....
                                          i use a different method now so i have not messed with it this way in a long time
                                          and you have a bunch of little things you did, which is not wrong but not needed. so they might be giving a problem.
                                          give me a bit i want to try something on my system
                                          • E
                                            escc1986
                                            sure , take as much time needed :) ... hope you could figure something out
