    spinner for Z-Axis with flight stick
    spinneranalogflight stick
    2 Posts 2 Posters 429 Views
      corminos
      I've successfully set up my analog flight stick to play Afterburner 2 on Mame2003. My problem now is that I don't have speed control.
      I have both a trackball and spinner on my control panel. What I was thinking was that I could somehow configure the spinner to be the analog Z-axis and then use if for the throttle control.
      When I test the controls in /dev/input/ the spinner is mouse0.
      I would like to ensure that the configuration is only for this game/emulator and I don't want to mess up Arkanoid or Tempest, which only works in Mame4All.
      Does anyone know if there is something that I can modify in the Retroarch.cfg file, or in the game setting for this?
      Thanks in advance.
        mitu Global Moderator @corminos
        @corminos said in spinner for Z-Axis with flight stick:
        You can chose a RetroArch based emulator for that specific rom (Afterburner 2) and you can also create a per-game config - https://retropie.org.uk/docs/RetroArch-Configuration/#hardcoded-configurations.
