    Openbor on usb
    retropie openbo
    25 Posts 3 Posters 882 Views
      cyperghost @wsamael
      @wsamael Please post following
      data of /opt/retropie/configs/ports/openbor/emulators.cfg
      There should be this entry (The %ROM% is vital)
      openbor= "pushd /opt/retropie/ports/openbor; /opt/retropie/ports/openbor/OpenBOR %ROM%; popd"
      default = "openbor"
      And your es_system.cfg should contain the following part
      <name>openbor</name>
          <fullname>OpenBOR</fullname>
          <path>/home/pi/RetroPie/roms/ports/openbor</path>
          <extension>.bor .BOR</extension>
          <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _PORT_ openbor %ROM%</command>
          <platform>pc</platform>
          <theme>openbor</theme>
      Can you check?
        cyperghost @cyperghost
        Tutorial how to install OpenBOR 3400 is here
        • W
          wsamael @cyperghost
          @cyperghost
          ok so I've delete the old version, and I've installed the 6xxx ( thanks you for the advice) and it's work. So, this version don't need to extract the .pak ?
            cyperghost @wsamael
            @wsamael Yes the 6xxx version does not need to extract PAKs and and ir offers much more games available to play. It's only the specific OpenBOR version here for RetroPie that makes a need to extract pack files.
            I just want to avoid confusion because the 6xxx port is not official supported here.
            • W
              wsamael @cyperghost
              @cyperghost
              ok I understand, Thanks for all :)
