    Naomi Atomiswave Help
    naomi atomiswavload videospi4
    2 Posts 2 Posters 1.1k Views
      polishedball
      Hi Everyone, FIrst off I am pretty new to the whole retropie, but have the basics of configs, ssh etc.
      I was on a non-supported image for the pi4, I wanted to be able to use the newest builds that are in the files page. So I decided to learn a bit more and build from the images there. I have been able to get all my themes setup, the only thing I havent figured system wise is where to put system load videos.
      The other problem I have experience is I can not get the Naomi / Atomiswave games to work that were working fine on the unsupported image. Pretty happy to get the emulators all working. ANy thoughts or ideas, what emulator shouls I try is there a custom setup config for it?
      Also I did read the read me first where it mentioned not to report problems on rpi4, but I saw others were asking questions on it, so I figured i'd try. If not allowed please lock or delete.
      • quicksilverQ
        quicksilver @polishedball
        @polishedball https://github.com/RetroPie/RetroPie-Setup/wiki/Runcommand#adding-custom-launching-images. This shows how to get launching images setup for each system.
        For Naomi and atomiswave you'll need to use lr-flycast and have the right bios. See here: https://github.com/retropie/retropie-setup/wiki/Dreamcast.
        Also wanted to say it's great you decided to build your own image, you'll learn a lot more this way.
