    Which wireed/wireless controllers are you using?
    controllerwiredwireless
    10 Posts 9 Posters 798 Views
    • E
      Eisbergsalat
      Hey Guys,
      I set up my raspberrypi3 as a retropi. Now im looking for controllers. Which controllers are you using? Can you recommend any 3rd party controllers? Like the cheapter ps3/nintendo/xbox like controller? Im looking for a cheaper solution than 4 controller 50€-75€ each just to play bomberman, mario kart, mario party or other party games with my roommates.
      If none wireless 3rd party controller is working than what wired controller can you recommend?
      GeekOBG 1 Reply Last reply Reply Quote 0
      • GeekOBG
        GeekOB @Eisbergsalat
        @Eisbergsalat, these are highly recommended and work perfectly fine with RetroPie. I have 3 different types of this brand:
        https://www.amazon.co.uk/stores/node/7264166031?_encoding=UTF8&field-lbr_brands_browse-bin=8Bitdo
          Old PS3 or WiiU Pro controllers are supported fine in wireless (Bluetooth) mode.
          • E
            Eisbergsalat @mitu
            i got a wii u pro generic one. But i dont get it to work but i guess its because its not a nintendo one...
            @GeekOB
            thanks i will look into those
            • IceChes1I
              IceChes1
              Logitech F310 is a great little controller for $20.
              HOME CONSOLE
              Pi 4
              SanDisk 64 GB
              Master branch install
              3.5 amp CanaKit PSU
              Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
              HANDHELD
              Pi 0 W
              SanDisk 32 GB
              Random image I found. Had a driver I needed.
              IPEGA PG-9157 USB Receiver
              • YFZdudeY
                YFZdude
                I have a few Logitech F310 wired controllers and 1 Logitech F710 wireless controller that I use. The wireless is great but for some older games the wired is almost necessary to get response time down.
                I have also successfully paired a Nintendo switch pro controller over blue tooth but I haven't used it much at this point. I wanted to keep it paired with my switch instead.
                  snock
                  sf30 pro bitdo
                  • SPS
                    SP
                    Phantom white Xbox One controller for pretty much everything and an M30 8bitdo controller for my Genesis and Saturn gaming.
                    • X
                      xFJSx
                      Usually I use a PS3 pad which works really well. Does anyone has a Retro-bit Saturn Controller Bluetooth or 2.4Ghz in use with Retropie?
                        danorigami
                        wireless super Nintendo work great $26 new from amazon
