    Latest automated buster build for pi4 does not work
    pi 4pi4buster
    7 Posts 3 Posters 358 Views
    • DarksaviorD
      Darksavior
      retropie-buster-4.5.16-rpi4.img.gz
      Fails to load emulationstation. The 4.5.14 image works.
        What's the error message if you try to run manually emulationstation from the terminal ?
        • DarksaviorD
          Darksavior @mitu
          @mitu Someone else let me know of the problem.
          /opt/retropie/configs/all/autostart.sh: line 1: emulationstation: command not found
          It can't find emulationstation to run it it manually. I checked retropie-setup. None of the core packages and none of the main packages are pre-installed. I can install them and then everything works but that defeats the purpose of a premade image.
          BuZzB 1 Reply Last reply Reply Quote 1
            BuZz administrators @Darksavior
            @Darksavior checking the build logs it looks like there were some failures with connectivity to raspbian repos. Could have been qemu but could have just been a bad mirror or so. I'm regenerating now. I'll update when complete.
              BuZz administrators
              Please try the 4.5.17 images that are now uploaded. Untested but hopefully ok. If not I'll dig a bit deeper.
              DarksaviorD 1 Reply Last reply Reply Quote 1
              • DarksaviorD
                Darksavior @BuZz
                @BuZz Seems to be fine now. Thanks. Core and main packages are preinstalled and retropie boots to ES.
                  @Darksavior thanks.
