    Problem with RetroPI installation on OSMC missing omxplayer repository
    osmcomxplayer
    5 Posts 3 Posters 1.4k Views
    • L
      LowLion
      Dear All,
      I'm trying to install RetroPie on OMSC using:
      https://github.com/RetroPie/RetroPie-Setup.git
      During installation, I have the following problem:
      Installing dependencies for 'emulationstation' : EmulationStation - Frontend used by RetroPie for launching emulators
      Did not find needed dependencies: omxplayer. Trying to install them now.
      Could not install package(s): omxplayer.
      It looks that omxplayer is no longer available in repository.
      Is there any workaround for that?
        BuZz administrators
        I can disable that dependency on osmc. Please can you give info about osmc version and hardware etc.
        • L
          LowLion
          Thank you for answer:
          I use RPI3 hardware
          I run the following commands:
          grep Kodi .kodi/temp/kodi.log | head -3
          2020-03-24 20:26:57.105 T:1915516464 NOTICE: Starting Kodi (18.5). Platform: Linux ARM (Thumb) 32-bit
          2020-03-24 20:26:57.105 T:1915516464 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
          2020-03-24 20:26:57.105 T:1915516464 NOTICE: Kodi compiled 2020-01-29 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.110 (264558)
          grep VERSION_ID /etc/os-release
          VERSION_ID="2020.01-2"
          • Z
            Zed_Blade
            Hi all!
            I'm facing the same issue. Just tried to install it today and wasn't successful at first.
            Here's my system info to add to the previous one:
            $ grep Kodi .kodi/temp/kodi.log | head -3
            2020-03-29 18:32:43.748 T:1915442736  NOTICE: Starting Kodi (18.6). Platform: Linux ARM (Thumb) 32-bit
            2020-03-29 18:32:43.748 T:1915442736  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
            2020-03-29 18:32:43.748 T:1915442736  NOTICE: Kodi compiled 2020-03-20 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.110 (264558)
            $ grep VERSION_ID /etc/os-release
            VERSION_ID="2020.03-1"
            However, in case anybody ends up here in the meantime, I did manage to solve the installation of emulstation with the instructions on https://github.com/hissingshark/retrOSMCmk2/issues/5
            • L
              LowLion
              thanks, it works for me
