    2 Controllers plugged in help!
    controller helpcontrollerhelp on usb
    3 Posts 2 Posters 263 Views
    • V
      vasquez109
      Got everything working finally and was quite happy playing until my partner wanted to play 2 player! I noticed that when both controllers are plugged in, the hotkey to quit back to Emulation Station (Select and Start) wont work. I have to unplug both controllers, then reinsert one of them and then it will work no problem with only one of the controllers inserted. Anyone else noticed this?
      Thanks.
        Only P1 has access to the hotkeys (including the one for exiting the emulators), so if you have 2 controllers plugged in, only the one for P1 would be able to quit.
        • V
          vasquez109
          Thank you, but when the second controller is plugged in P1 cannot hotkey out. Both controllers have to be pulled and P1 reinserted to quit. Any ideas?
