    How to read CD games inside their own folder?
    help
    6 Posts 3 Posters 224 Views
    • I
      Imgema
      I keep my CD games collection in a subfolder for each game. I do this because each game has multiple files like a cue file and a bunch of bins. I don't use just one folder for all files.
      How can i make Emulationstation see those files in the folders and show them in the menu like normal roms? Other frontends have the option to "see" inside subfolders but i can't find anything here.
      • quicksilverQ
        quicksilver @Imgema
        @Imgema what cd based system are you referring to? You should look into converting your .bin/.cue files into .chd. That way you have one file per game and don't need sub folders at all.
        • George SpiggottG
          George Spiggott
          Some games won't play when converted. You can keep all the files in a folder and direct the .CUE file to look for the files in the folder. I had to do this with Seek & Destroy for the Amiga CD32 and just today I have set up Xenon II - Megablast CDTV in the same way.
          PS1 games can be converted to .PBP files which has an additional benefit of reducing the file size.
          Currently running:
          Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
          ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
          • quicksilverQ
            quicksilver @George Spiggott
            @George-Spiggott for emulators that support .chd I have never had a problem with them not working. Not saying it isn't possible but it would have to be pretty rare.
            • George SpiggottG
              George Spiggott
              Only two games for me so far, Skidmarks 2 and Seek & Destroy, both for Amiga/Amiberry. I didn't convert Xenon 2 so it may well convert fine, I just haven't tried yet.
              Currently running:
              • I
                Imgema
                So i get there is no way for Emulationstation to look into subfolders? I have to convert my whole collection or edit their cues? (not possible to edit them this way, too many files)
                I do use Hyperspin/Rocketlauncher/Launchbox already and EmulationStation seem lo lack very basic functions like choosing a simple path for your media files and now this. I managed to find a dirty solution for for the paths but i can't seem to find something for the subfolders. Scrappers don't seem to have anything about them either so that means there's nothing i can do to the gamelist.xml. I really don't want to convert the games because i use a lot of emulators for testing, etc, and not everything is going to be compatible afterwards.
