    Help
    reboot loopblackscreen
    10 Posts 4 Posters 1.1k Views
    • X
      xmrdarky
      OK I did my retro pie with a 32 gig image file from arcade punk and it just kept re booting can never get it to work so I went ahead and redid my SD card with just the retro pie image itself and all it would do would keep re booting again know it's at a black screen I have a video if any one what's to contact me on Facebook
      quicksilverQ 1 Reply Last reply Reply Quote -1
      • quicksilverQ
        quicksilver @xmrdarky
        @xmrdarky 3rd party images are not supported here especially ones loaded with roms. When you redid your image where did you get it from? For future reference a more descriptive title would be helpful as well.
        X 1 Reply Last reply Reply Quote 0
        • X
          xmrdarky @quicksilver
          @quicksilver I got the retro pie image from this site itself
          • quicksilverQ
            @xmrdarky what power supply are you using? Can you try a different sd card?
            • X
              @quicksilver I have the usb powersuply and this is the 2 sd card I have used
              markyh444M rbakerR 2 Replies Last reply Reply Quote 0
              • markyh444M
                markyh444 @xmrdarky
                @xmrdarky this sounds like a Pi or SD card issue. How did you copy the image to the card? Did you follow the notes in the documentation on how to setup?
                Have you checked this out as agreed when you signed up to the forums?
                Retropie in a PSX - Pi3
                • rbakerR
                  rbaker @xmrdarky
                  @xmrdarky said in Help:
                  this is probably an issue if you are powering through a usb port
                  X 1 Reply Last reply Reply Quote 1
                  • X
                    xmrdarky @rbaker
                    @rbaker naver gave man any problems be for
                    • X
                      xmrdarky @markyh444
                      @markyh444 the way it told me to step by step
                      • markyh444M
                        markyh444 @xmrdarky
                        @xmrdarky Can you please fill in the information as requested here (https://retropie.org.uk/forum/topic/3/read-this-first) so people on the forum can try and help. Each setup can be wildly different and knowing all this goes a long way to assisting. Like @rbaker says, it sounds like it could be a power issue if you are running it just off a USB charger, such as a phone charger, but we wont know unless you give details.
