    Bluetooth dongle won't work
    bluetoothdongleraspberry pi 2b
    7 Posts 2 Posters 1.3k Views
      dingdongdynamo
      So I bought a USB Bluetooth dongle for my Pi 2. It's this one (sorry that the site is in Danish) and thought that would be fine for my Pi 2. However, while it's recognized, I can't seem to turn it on as I get the following error message:
      pi@retropie:~ $ hciconfig hci0 up
      Can't init device hci0: Operation not permitted (1)
      Here are some info:
      pi@retropie:~ $ hciconfig -a
      hci0:   Type: Primary  Bus: USB
              BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
              DOWN
              RX bytes:1722 acl:0 sco:0 events:90 errors:0
              TX bytes:1104 acl:0 sco:0 commands:90 errors:0
              Features: 0xff 0xff 0x87 0xfa 0xdb 0xbf 0x7b 0x83
              Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
              Link policy: RSWITCH HOLD SNIFF PARK
              Link mode: SLAVE ACCEPT
      pi@retropie:~ $ hcitool dev
      Devices:
      Also:
      Model: Raspberry Pi 2 Model B Rev 1.1
      RetroPie version: Says "Linux retropie 4.14.98-v7+" when I login via SSH.
      Built From: SD image on RetroPie website.
      Any ideas as to how I get it working? Or should I have gotten a different dongle?
        @dingdongdynamo said in Bluetooth dongle won't work:
        That's because you need admin rights for this operation, you can prefix the command with sudo to work. Regardless, it should work without doing this manual config.
        Can you run
        rfkill list all
        and post the output ? Maybe the BT radio is soft locked.
          dingdongdynamo
          @mitu said in Bluetooth dongle won't work:
          hciconfig hci0 up
          Still getting an error with sudo:
          pi@retropie:~ $ sudo hciconfig hci0 up
          Can't init device hci0: Operation not supported (95)
          It's not soft locked:
          pi@retropie:~ $ rfkill list all
          1: phy0: Wireless LAN
                  Soft blocked: no
                  Hard blocked: no
          2: hci0: Bluetooth
                  Soft blocked: no
                  Hard blocked: no
          Should all dongles be compatible with a Pi 2 with RetroPie?
            mitu Global Moderator @dingdongdynamo
            RetroPie is just plain Raspbian Lite at the OS level, so as long as it's compatible with Linux, the dongle should work. It might be that this particular device is not Linux compatible. For the record, this is the output of my dongle (which seems similar to this one) on the same Raspbian version:
                    BD Address: 00:1A:7D:DA:71:09  ACL MTU: 310:10  SCO MTU: 64:8
                    UP RUNNING PSCAN
                    RX bytes:758 acl:0 sco:0 events:52 errors:0
                    TX bytes:1725 acl:0 sco:0 commands:44 errors:0
                    Features: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
                    Class: 0x000000
                    Service Classes: Unspecified
                    Device Class: Miscellaneous,
                    HCI Version: 4.0 (0x6)  Revision: 0x22bb
                    LMP Version: 4.0 (0x6)  Subversion: 0x22bb
                    Manufacturer: Cambridge Silicon Radio (10)
            Can you get the dmesg output from unplugging and plugging the device:
            # unplug the dongle
            sudo dmesg -c
            # plug the dongle back and get the output of the follwing command
            dmesg
              dingdongdynamo
              Thanks for helping me out here. This is what I get:
              pi@retropie:~ $ dmesg
              [69061.275907] usb 1-1.2: new full-speed USB device number 9 using dwc_otg
              [69061.408272] usb 1-1.2: New USB device found, idVendor=0a12, idProduct=0001
              [69061.408292] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
              [69061.408306] usb 1-1.2: Product: USB1.1-A
              But yeah, it's probably a dongle that isn't compatible with Linux - I didn't know I should've checked for that. Unless you have something I can try, I'll probably just order a new one.
                I'd say exchange it if possible (if you just bought it).
                  dingdongdynamo @mitu
                  @mitu Will do. Thanks.
