    Help with RetroPie on Odroid
    help mesplash screencontrollerskeyboardboot problem
    3 Posts 2 Posters 316 Views
      Pandamansam
      Hi all,
      I need some help with my raspberry pi that I revieved as a present for Christmas. From what I can gather it is a bundle package from Odroid called - Retromania XU4.
      The problems started straight out of the box as the controller that came with the bundle only worked when I was inches away from the machine. So I tried to connect my xbox one and ps3 controllers via the USB ports, still nothing.
      Whislt updating the raspberry pi I've ran in to a brick wall, my keyboard no longer works and it boots to the image I've attached to this post.!
      Any help is greatly appreciated, I've had this thing for four months now and pretty much gave up on it. Seems like a shame for it to become a £180 paper weight.
      Thanks guys, if you require more information I'll gladly provide any.
        mitu Global Moderator @Pandamansam
        @Pandamansam said in Help with RetroPie on Odroid:
        We don't support sellers that bundle RetroPie - it's against the project's license. If you want to use RetroPie on Odroid XU4, check out the Docs on how to install it.
          Pandamansam @mitu
          @mitu I do apologise, I didn't know it was against your licence but I can see why.
          Thank you for your help, I will start over and hopefully it will fix my problem.
