    Problema Controlblock rev2.1
    controlblock
    10 Posts 3 Posters 844 Views
      Mario
      Hola a todos, tengo una raspberry pi3 b y un controlcblock rev2.1
      Version oficial de Retropie: retropie-4.5.1-rpi2_rpi3
      Dispositivo USB: teclado USB
      Instalo todo siguiendo estos pasos:
      https://github.com/petrockblog/ControlBlockService2#downloading
      Errores:
      acceso denegado: /etc/controlblock config.cfg
      Los botones no se reconocen y el interruptor no funciona correctamente.
      pueden ayudarme?
      Un saludo.
        Mario
        Hola de nuevo, adjunto foto del controlblock.
        agradezco cualquier ayuda.
        Saludos.
        • chicueloC
          chicuelo
          Escribi tu consulta en ingles Mario, acá nadie te va a responder en español. Proba buscar en YouTube alguna solucion
            Mario
            Muchas gracias por tu interes.
              Mario
              Hi everyone, I have a raspberry pi3 b and a controlcblock rev2.1
              Official version of Retropie: retropie-4.5.1-rpi2_rpi3
              USB device: USB keyboard
              I install everything by following these steps:
              Mistakes:
              access denied: /etc/controlblock config.cfg
              The buttons are not recognized and the switch does not work properly.
              can you help me?
              A greeting.
                mitu Global Moderator @Mario
                @Mario Try installing the driver from the RetroPie-Setup script, from the drivers section, then enable the service if installation is fine.
                  Mario @mitu
                  @mitu Thank you very much, tomorrow I will try.
                  Greetings.
                    Mario @Mario
                    @mitu I still have the same problems, i'm sure I'm still doing something wrong.
                    I follow these steps first:
                    sudo apt-get update
                    sudo apt-get dist-upgrade
                    sudo apt-get install git
                    cd
                    git clone --depth=1 https://github.com/RetroPie/RetroPie-Setup.git
                    cd RetroPie-Setup
                    sudo ./retropie_setup.sh
                    Finally I follow these steps:
                    git clone --recursive https://github.com/petrockblog/ControlBlockService2.git
                    cd ControlBlockService2
                    mkdir build
                    cd build
                    cmake ..
                    make
                    sudo make install
                    sudo make installservice
                    I apologize for my ignorance, any ideas?
                    Greetings and thank you.
                      If you already have a RetroPie image, you just need to start the setup script, then go to Manage packages -> Manage driver packages and you can install the controlblock package from there.
                        Mario
                        Hello everyone, in the end I will use Recalbox with two USB interfaces.
                        For me it is much easier.
                        Thank you all for the help, best regards.
