    Connecting PS4 controller problems - worked yesterday now creating device failed org.bluez.error.alreadyexists
    ps4 controller
    1 Posts 1 Posters 309 Views
      alistairgd
      After a bit of faffing about yesterday, I finally got my PS4 connected by bluetooth.
      I was not sure when I switched the RasberryPi on today, and switched on the controller, if they should "just work" or if they need paired every time you switch it on? So that's my first question?
      (side question - same with wifi - will I need to go into settings and connect wifi each time I start pi or only once)
      So because the controller was having no effect on retropie, I went though the connection process again, but now I get this error when I select the wireless controller from the BT list.
      Any guidance on how this should work, and how to resolve this issue would be great, thanks.
