    Problem with usbromservice.
    usbromserviceusbmount
    2 Posts 2 Posters 356 Views
    • windgW
      windg
      Pi Model or other hardware: Pi3
      Power Supply used: Official
      RetroPie Version Used : 4.5.18
      Built From: (Pre made SD Image on RetroPie website)
      I decided to uninstall/install RetroPIe from the menu . The process was completed without any problems except that usbromservice does not work (i have install it).
      I am not 100% sure, but i think the problem is with the package usbmount(not installed?). If i install it from the terminal before usbromservice then, everything works ok.
        dankcushions Global Moderator @windg
        @windg usbmount is included in the image, but not in the manual installation. if you install via a manual installation, as it appears you have done, you will have to manually install it after the fact via the packages menu.
