    Issues with lr-pcsx-rearmed
    pcsxlr-pcsx-rearmedpcsx-rearmed
    6 Posts 2 Posters 531 Views
      patocox
      Hi All,
      Just started to try using the playstation 1 emulator. I have all the correct BIOS files and my roms are in cue/bin format, however, the performance on the emulator is very poor with lr-pcsx-rearmed - latency, jittery, choppy. Im running a 3b+.
      If I run the pcsx-rearmed emulator every works fine. No issues. I read previously to turn off rewind and a few other features but seem to be off by default.
      Also, the playstation 1 page on the docs is dead. I was referencing https://github.com/RetroPie/RetroPie-Setup/wiki/Playstation-1 for guidance.
      • quicksilverQ
        quicksilver @patocox
        @patocox in the retroarch quick menu options make sure enhanced resolution is turned off.
          patocox
          Just turned it off, but no improvement @quicksilver
          • quicksilverQ
            @patocox lr-pcsx-rearmed should work fine out of the box. Are you using the official retropie image? What settings have you changed from default?
              patocox
              ok - i am using the official image but I have made some mods. Let me go back and review. Just knowing that it should work tells me it has to be my configs etc.
              Thanks for the sanity check @quicksilver
                patocox
                @quicksilver
                please file this under bad behaviour on my part. Updating the setup-script and getting from source again fixed it..
                Thanks... sorry for the run around.
