    Very quick Q: does anything run Street Fighter Ex or Thunder Blade well?
    mamestreet fighterthunder blade
    15 Posts 4 Posters 1.9k Views
      SpudsMcToole Banned
      As per title, really.
      SFEx runs in lr-mame2010 but painfully slowly, lr-mame2003 and 2003plus aren't interested and nor is FBNeo.
      Thunder Blade is playable but a bit slow and scratchy in lrmame2010, while the graphics are messed up in lr-mame2003/plus. It seems to run smooth and fast in FBNeo, with the tiny hitch that absolutely none of the controls except insert coin, start and the two fire buttons work.
      • arcadez2003A
        arcadez2003
        If it was possible to have Thunder Blade playable in MAME2003-plus it would have done already, but since it's not why dont you try it
        in one of the older advance MAME ports.?? you should get better performance using one of those cores vs MAME2010.
        Arcade Addict
        sirhenrythe5thS S 2 Replies Last reply Reply Quote 0
        • sirhenrythe5thS
          sirhenrythe5th @arcadez2003
          @arcadez2003 just for interest: why should he use an older version of AdvanceMame?
          Thunderblade also runs with v3.8.
          I use AdvanceMame since the the beginning and my experience is that only one single game does not work with the newer 3.x but only with 0.9x: Outfoxies.
          RetroRatio: 1.88
          Started Games beaten: 2,47%
          Site Rank: 4382/93743 ranked users (TOP 4.76%)
          Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
            Thunder Blade seems to work fine with FBNeo - it's using the analog controls and the buttons work.
              SpudsMcToole Banned @arcadez2003
              @arcadez2003 Sadly none of the advmames or mame4all or lr-mame2000 seem to be interested :(
              • sirhenrythe5thS
                sirhenrythe5th @SpudsMcToole
                @SpudsMcToole as mentioned: Thunderblade is running well with AdvanceMame, if you mean "running" by saying "is interested in".
                RetroRatio: 1.88
                  SpudsMcToole Banned @mitu
                  @mitu Unfortunately I'm using a digital arcade joystick and can find no way to change the controls.
                    SpudsMcToole Banned @sirhenrythe5th
                    @sirhenrythe5th Hmm, which ROMset?
                    • sirhenrythe5thS
                      @SpudsMcToole AdvanceMame uses the 0.106 romset
                      RetroRatio: 1.88
                        @sirhenrythe5th Oh lordy, I only have 37b5, 78, 139, 161 and 218 :D
                        Thanks for the info, will see what I can track down.
                          SpudsMcToole Banned @SpudsMcToole
                          @SpudsMcToole Yep, got it working in AdvMAME 1-4, many thanks. Now to try to work out how to switch that bloody smoothing off...
                            mitu Global Moderator @SpudsMcToole
                            @SpudsMcToole said in Very quick Q: does anything run Street Fighter Ex or Thunder Blade well?:
                            Did you try to use the Analog-to-Digital settings for RetroArch to make the D-Pad appear as an analog device ?
                              @mitu No idea what that means, unfortunately :(
                              • sirhenrythe5thS
                                @SpudsMcToole it is an option im retroarch/controls which allows you to activate the analog stick for directional Inputs in addition to the d-pad.
                                Same as if you set in (Advance)Mame the inputs for directions to the d-pad as well as to the analog axis.
                                I did this for all emulators btw ๐Ÿ˜‰
                                RetroRatio: 1.88
                                  @sirhenrythe5th Just did it by changing the User 1 Input Binds under Settings>Input, then Saving Autoconfig. Really really hope I haven't just saved a new set of control overrides for all FBNeo games :(
