    lr-mupen64plus-next and N64 controller input issues
    lr-mupen64plusretrolinkautoconfigb buttonissue
    21 Posts 8 Posters 9.4k Views
      badviper
      This has been driving me crazy for the past few days...
      Setup:
      • Raspberry Pi 4 with Vilros PSU
      • Retrolink N64 USB controller
      • Fresh, updated Raspbian Lite with Wifi and SSH enabled, stock video settings
      • Latest RetroPie setup script with basic install
      Scenario:
      • Testing Mario Kart 64 and Super Smash Bros on lr-mupen64plus-next using 49-21 video setting (640x480)
      • Controller mapped in ES using recommended mappings
      Issue:
      • Controller buttons work fine and act as they should in ES, jstest, and in the runcommand window
      • In the emulator, the physical B button acts as the logical A button, and the physical A button doesn't work for the logical B button (can't back out of menus, etc.)
      • Swapping the A and B button mappings in "/opt/retropie/configs/all/retroarch/autoconfig/Generic USB Joystick .cfg" causes the physical A button to work as expected, but the physical B button still will not work for the logical B button (can't back out of menus, etc.)
      I've also tried mapping the logical B button to various other physical buttons, and pressing every button on the controller, and it just will not work. I've also tried removing all the hotkeys from the config file and it has no affect. This is driving me crazy, where else should I check to see what is causing the logical B button to get unmapped or disabled? I've included my joystick config file below if anyone would like to review it. Thanks in advanced!
      input_device = "Generic   USB  Joystick  "
      input_driver = "udev"
      input_enable_hotkey_btn = "7"
      input_r_y_minus_btn = "0"
      input_l_btn = "4"
      input_load_state_btn = "4"
      input_r_y_plus_btn = "2"
      input_up_btn = "h0up"
      input_left_btn = "h0left"
      input_r_x_minus_btn = "3"
      input_l_y_plus_axis = "+1"
      input_l_x_plus_axis = "+0"
      input_right_btn = "h0right"
      input_l2_btn = "7"
      input_l_x_minus_axis = "-0"
      input_r_x_plus_btn = "1"
      input_r_btn = "5"
      input_save_state_btn = "5"
      input_l_y_minus_axis = "-1"
      input_down_btn = "h0down"
      input_start_btn = "9"
      input_exit_emulator_btn = "9"
      input_b_btn = "8"
      input_reset_btn = "8"
      input_a_btn = "6"
        When testing via jstest, is the button number for B the same (8 it seems) the same as the one in the auto-configuration ?
        Is N64 the only system that exhibits this behavior, or the B button doesn't work in other systems also ?
          badviper
          Correct, jtest confirmed that button 8 is the physical B button, as it is mapped in the auto-configuration file.
          Just tested with lr-snes9x on two ROMs and both A and B buttons are mapped correctly and working as expected using the Retrolink N64 controller. Also tested with lr-gambatte on two ROM's and A and B are also working as expected.
          Then I went to go and test with mupen64plus-GLideN64, but I had to modify /opt/retropie/configs/n64/InputAutoCfg.ini because the ES mapping script left it in a dysfunctional state (check out C button D):
          ; Generic   USB  Joystick  _START
          [Generic   USB  Joystick  ]
          plugged = True
          plugin = 2
          mouse = False
          AnalogDeadzone = 4096,4096
          AnalogPeak = 32768,32768
          Mempak switch =
          Rumblepak switch =
          C Button U = button(0)
          L Trig = button(4)
          C Button D = button(6) button(2)
          DPad U = hat(0 Up)
          DPad L = hat(0 Left)
          C Button L = button(3)
          Y Axis = axis(1-,1+)
          X Axis = axis(0-,0+)
          DPad R = hat(0 Right)
          Z Trig = button(7)
          C Button R = button(1)
          R Trig = button(5)
          DPad D = hat(0 Down)
          Start = button(9)
          A Button = button(8)
          ; Generic   USB  Joystick  _END
          After modifying that to match the actual button values (A = button 6, B = button 8, C down = 2), both A and B buttons were functioning as expected in ROM's. At this point, the issue still only exists in lr-mupen64plus-next, as far as I can tell.
            Then check if you have any core remaps for the N64 core.
              badviper
              Apologies, I'm still pretty new to this project, where can I check that? Thanks for your assistance, mitu!
                mitu Global Moderator @badviper
                Check the \\retropie\configs\n64 folder and see if you have any. Also, when starting a game with the N64 core, check if any overrides/remaps are applied, there should be a message at the bottom if any are loaded.
                  badviper
                  Ah, thank you. No I don't see any remaps, and when starting a game the only message is Generic USB Joystick configured in port #0. As I mentioned, this was tested on a clean install and I only used the joystick mapping script when booting ES the first time to perform the mapping.
                  I think it's something to do with the fact that it didn't configure the B input initially as seen in the InputAutoCfg.ini file. Although adjusting the mapping in /opt/retropie/configs/all/retroarch/autoconfig/Generic USB Joystick .cfg seems to be futile.
                    badviper @mitu
                    @mitu just for curiosity sake I took a Raspberry Pi 3 and loaded the latest 4.5.1 RetroPie image on a fresh SD card. I followed the same procedure in my original test, only enabled ssh and wifi, and configured the Retrolink N64 controller using the ES mapping prompt and recommended mappings for lr-mupen64plus.
                    After checking /opt/retropie/configs/all/retroarch/autoconfig/Generic USB Joystick .cfg and /opt/retropie/configs/n64/InputAutoCfg.ini my results are identical to my previous test. The joystick configuration in /configs/retroarch/autoconfig/ is 100% correct however in lr-mupen64plus the B button controls the A button, and the A button does nothing. And the joystick configuration in /configs/n64/ is incorrect as in my previous test, specifically for the A, B, and C down buttons:
                    B button mapping missing
                    Once I fix those, native mupen64 works fine, but altering the libretro mapping doesn't.
                    At this point, is it possible there is some bug in the mapping of controls for lr-mupen64plus? Or a possible incompatibility with this controller? Really appreciate any thoughts you may have.
                      You can open the RetroArch RGUI and check in the Controls -> Port 1 Binds how the gampad's buttons are mapped to the emulator buttons (N64 gamepad).
                      I'm not aware of any issue with lr-mupen64 regarding the controller mapping, but since RetroArch is handling the input part, it would happen for all games. Do other systems have working A/B buttons ?
                      The libretro project has a joypad auto-configuration database, I there is mapping for a similar controller here, but I don't think is the same device.
                      It's weird that both the RetroArch and Mupen64plus mapping are not correctly created - can you also post the EmulationStation input config, from \\retropie\configs\all\emulationstation ?
                      B 2 Replies Last reply Reply Quote 0
                        badviper @mitu
                        @mitu here's what the RetroArch RGUI had for controller mappings. The game's B button was mapped to some "Y button (left)", and the physical A button on the controller was mapped to (C1), whatever that is; Google Drive Link.
                        And the mappings you had me check in es_input.cfg are exactly as they should be:
                        <?xml version="1.0"?>
                        <inputList>
                          <inputAction type="onfinish">
                          </inputAction>
                          <inputConfig type="joystick" deviceName="Generic   USB  Joystick  " deviceGUID="03000000790000000600000010010000">
                            <input name="rightanalogup" type="button" id="0" value="1"/>
                            <input name="pageup" type="button" id="4" value="1"/>
                            <input name="rightanalogdown" type="button" id="2" value="1"/>
                            <input name="up" type="hat" id="0" value="1"/>
                            <input name="left" type="hat" id="0" value="8"/>
                            <input name="rightanalogleft" type="button" id="3" value="1"/>
                            <input name="leftanalogdown" type="axis" id="1" value="1"/>
                            <input name="leftanalogright" type="axis" id="0" value="1"/>
                            <input name="right" type="hat" id="0" value="2"/>
                            <input name="leftanalogleft" type="axis" id="0" value="-1"/>
                            <input name="rightanalogright" type="button" id="1" value="1"/>
                            <input name="pagedown" type="button" id="5" value="1"/>
                            <input name="leftanalogup" type="axis" id="1" value="-1"/>
                            <input name="down" type="hat" id="0" value="4"/>
                            <input name="start" type="button" id="9" value="1"/>
                            <input name="b" type="button" id="8" value="1"/>
                            <input name="a" type="button" id="6" value="1"/>
                          </inputConfig>
                        </inputList>
                        I'll try that config file from the database on both setups and see if that yields any different results.
                          badviper @mitu
                          @mitu reporting back after using the input file you linked, which does match the button mappings. While it's cleaner and easier to read in the RetroArch RGUI, the result is identical; Google Drive Link
                          And to answer your earlier question about A and B controls with this Retrolink N64 controller on other RetroArch cores, here is the button mapping in lr-gambatte, which is indeed correct; Google Drive Link
                          Again, really appreciate your help with this, I'm honestly stumped.
                            Weird behavior, indeed. Looking at how the gamepad configuration is reported for my controller, the only difference I see is that all buttons are marked with Auto (i.e. taken from the gamepad auto-config file), while on yours some buttons are not (Y Button, Select, X button).
                            ec5050cc-d2d2-428a-b131-4ed3a3aef599-image.png.
                            Can you try resetting the RetroArch's main configuration file (/opt/retropie/configs/all/retroarch.cfg) to default - copy over the retroarch.cfg.rp-dist and see if it makes a difference.
                              badviper @mitu
                              @mitu resetting RetroArch's main configuration yielded the same results. I think I figured it out though...
                              Looking back at the wiki, I decided to try the mapping that was documented for Mupen64plus, where the game's A and X buttons are mapped to controller's C down and C left, respectively. After firing up the game, the controller's A and B buttons worked as expected! So it looks like the mapping of B and Y buttons in RetroPie/ES are being mapped to the game's A and B buttons in lr-mupen64plus and lr-mupen64plus-next, respectively. Given that, the documentation for lr-mupen64plus is outdated.
                              So I'll go ahead and mark this as solved and thank you for your help!
                              In case anyone stumbles upon this thread later having issues with your Retrolink N64 controller button mapping, here is my recommended joystick config:
                              input_device_display_name = "Retrolink N64 USB controller"
                              input_vendor_id = 121
                              input_product_id = 6
                              input_a_btn = "2"
                              input_x_btn = "3"
                              input_l_btn = "4"
                              input_r_btn = "5"
                              input_b_btn = "6"
                              input_l2_btn = "7"
                              input_y_btn = "8"
                              input_enable_hotkey_btn = "9"
                              input_menu_toggle_btn = "3"
                              input_exit_emulator_btn = "7"
                              input_b_btn_label = "B"
                              input_y_btn_label = "Y"
                              input_x_btn_label = "X"
                              input_start_btn_label = "Start"
                              input_up_btn_label = "D-Pad Up"
                              input_down_btn_label = "D-Pad Down"
                              input_left_btn_label = "D-Pad Left"
                              input_right_btn_label = "D-Pad Right"
                              input_a_btn_label = "A"
                              input_l_btn_label = "L"
                              input_r_btn_label = "R"
                              input_l2_btn_label = "Z"
                              input_l_x_plus_axis_label = "Joystick Right"
                              input_l_x_minus_axis_label = "Joystick Left"
                              input_l_y_plus_axis_label = "Joystick Down"
                              input_l_y_minus_axis_label = "Joystick Up"
                              input_r_x_plus_btn_label = "C Right"
                              input_r_x_minus_btn_label = "C Left"
                              input_r_y_plus_btn_label = "C Down"
                              input_r_y_minus_btn_label = "C Up"
                                ptindian95
                                This thread has been exactly what I'm looking for! I've been having the same problems listed here.
                                @badviper I replaced my ~/.config/retroarch/autoconfig/ Generic\ \ \ USB\ \ Joystick\ \ .cfg with exactly what you listed above and playing the roms works great! The only problem is when you open the RetroArch RGUI, the controls are all wonky. I have a hunch that it's reading mappings from this file instead: opt/retropie/configs/n64/InputAutoCfg.ini, and my mappings in that file are probably still wrong.
                                Do you mind posting what you have in that file?
                                  badviper @ptindian95
                                  @ptindian95 glad you were able to benefit from this! I love the community and when people can find solutions to their issues.
                                  I also experience issues with the RetroArch RGUI (for instance the C-down button controlling "A" in the menu). I honestly doubt that it's getting the mapping from InputAutoCfg.ini as it's a mupen64plus-specific configuration. Regardless, here is my config file (excluding other controllers):
                                  ; InputAutoCfg.ini for Mupen64Plus SDL Input plugin
                                  plugged = True
                                  plugin = 2
                                  mouse = False
                                  Mempak switch =
                                  Rumblepak switch =
                                  L Trig = button(4)
                                  Start = button(9)
                                  R Trig = button(5)
                                  Z Trig = button(7)
                                  DPad U = hat(0 Up)
                                  C Button D = button(2)
                                  A Button = button(6)
                                  B Button = button(8)
                                    ptindian95 @badviper
                                    @badviper Yeah you're right, messing with my InputAutoCfg.ini just messed everything up. I think I've just decided to accept that the RetroArch RGUI has different controls (exactly like you explained with C-Down controlling A in the menu). Small price to pay for the mappings working in the actual game. Thanks again!
                                    • neekN
                                      neek
                                      I also just wanted to chime in and say I bumped into this exact issue, and after hunting around for a few days, I found this thread and had it fixed in a few seconds. I appreciate you posting a follow-up for the community.. it helped me a lot!
                                        Alien @neek
                                        @neek said in lr-mupen64plus-next and N64 controller input issues:
                                        +1 here, this solution made my day. Thanks a lot!
                                          bmay
                                          @badviper's configuration also fixed a similar problem that I had with the n64 retrolink z button not being mapped on my second player controller. Thanks!
                                          • F
                                            floppes
                                            I had a very similar issue with my "HuiJia USB GamePad" adapter. That's a USB adapter for two original N64 controllers:
                                            I had no issues so far with Mupen64Plus on a Rasperry Pi 3. After switching to a Raspberry Pi 4 and the latest RetroPie 4.7.1, I started using lr-mupen64plus-next. The B button acted like it was the A button and no button would act like the B button.
                                            @badviper s findings helped me solve it: I had to remap the B button and add a fake Y button. Additionally, I increased the analog sensitivity because the raw analog values would max out at about -22000/+22000 and in most games navigating the menus wasn't possible.
                                            I have the impression that the two controls graphics in the docs should be switched.
                                            Here are my config files for anyone facing the same issues with the HuiJia adapter and mupen64plus-next:
                                            configs/all/retroarch/autoconfig/HuiJia USB GamePad.cfg: (note that there are two spaces between 'HuiJia' and 'USB', but the forum shows only one)
                                            input_device = "HuiJia  USB GamePad"
                                            input_a_btn = "1"
                                            input_b_btn = "2"
                                            input_l_btn = "6"
                                            input_r_btn = "7"
                                            input_l2_btn = "8"
                                            input_r_y_plus_axis = "+2"
                                            input_r_y_minus_axis = "-2"
                                            input_r_x_plus_axis = "-3"
                                            input_r_x_minus_axis = "+3"
                                            input_enable_hotkey_btn = "8"
                                            configs/n64/retroarch.cfg:
                                            input_remapping_directory = "/opt/retropie/configs/n64/"
                                            input_player1_b_btn = "1"
                                            input_player1_y_btn = "2"
                                            input_player2_b_btn = "1"
                                            input_player2_y_btn = "2"
                                            input_analog_sensitivity = "1.400000"
                                            configs/n64/InputAutoCfg.ini (just for reference as this is not used by lr-mupen64plus-next, only by Mupen64Plus):
                                            ; HuiJia  USB GamePad_START
                                            [HuiJia  USB GamePad]
                                            plugged = True
                                            plugin = 2
                                            mouse = False
                                            AnalogDeadzone = 1024,1024
                                            AnalogPeak = 19000,19000
                                            Mempak switch =
                                            Rumblepak switch =
                                            DPad U = hat(0 Up)
                                            C Button U = axis(2-)
                                            C Button D = axis(2+)
                                            C Button L = axis(3+)
                                            C Button R = axis(3-)
                                            L Trig = button(6)
                                            Z Trig = button(8)
                                            R Trig = button(7)
                                            Start = button(9)
                                            A Button = button(1)
                                            B Button = button(2)
                                            ; HuiJia  USB GamePad_END
