Navigation
    • Search
    My Console Themed Overlays for Retroarch
    Projects and Themes
    bezel console gaming overlay retroarch
    8
    76
    3081
    • Orionsangel
      Orionsangel last edited by Orionsangel
      These custom console themed overlays were edited and assembled by me to play your retro console games with a unique nostalgic bezel on Retroarch. Please enjoy and have fun. Please give me credit and the others involved if you use it on your Youtube channel. Thanks.
      Most of the original artwork came from ReignStumble.
      Credit is given to RetroKenesis for the bezel frames.
      You can download all my console themed overlays here - http://bit.ly/2nbRtPs
      Here's some examples...
      You can see more out at my Youtube channel - https://bit.ly/2RKzfS6
      Also, Here's a Tutorial on how to add them to Retroarch.
      Clyde 1 Reply Last reply Reply Quote 6
      • Orionsangel
        Here's a Tutorial on how to fix the gap on the left side of the screen for some Atari and Master System games when using overlays on Retroatch.
        • Orionsangel
          I made this bezel a while back for the Streets Of Rage games on Sega Genesis for Retroarch. Today I updated it a little bit and decided to release it. Seems appropriate now with the release of Streets of Rage 4. I hope you guys like it.
          • simpleethat
            simpleethat last edited by
            Nice! I've been looking for some simple and not overly distracting overlays for my build. Any chance of an SG-1000 overlay though?
            • ratedrguy
              ratedrguy last edited by
              These are fantastic, Orion. Thank you for sharing and all of your hard work!
              • Clyde
                Clyde @Orionsangel last edited by
                @Orionsangel Any chance that you could register at Github and put the overlays there? It has several advantages over a single-file Mediafire download. It's more transparent, can be downloaded and updated easily from the Linux/Retropie console and others could contribute by making pull requests from their own Github repositories, which many of the content creators here already have. Finally, someone could easily continue your work if you ever happen to abandon it.
                Just a friendly suggestion. I just saw too many great creations become inaccessible only because their download link vanished after some time.
                Orionsangel 1 Reply Last reply Reply Quote 2
                • sad_muso
                  sad_muso last edited by
                  Thanks, these are rad! It's my first time using overlays and for some reason they aren't working - my games are set to 4:3 but all I get is a darker image (the opacity no doubt) and black borders with no actual overlay. What am I doing wrong?
                  wmarcio 1 Reply Last reply Reply Quote 0
                  • wmarcio
                    wmarcio @sad_muso last edited by wmarcio
                    @sad_muso same thing here.
                    I on retropie 4.6 raspbian 10, rpi 3b+ and I installed the official image.
                    sad_muso 1 Reply Last reply Reply Quote 0
                    • sad_muso
                      sad_muso @wmarcio last edited by
                      @wmarcio Yup, exactly the same setup here too. Is it related to resolution? Mine is just on whatever the default is (assume 1080p)
                      • wmarcio
                        @sad_muso I don't think so, mine is in 720p resolution.
                        ratedrguy 1 Reply Last reply Reply Quote 0
                        • ratedrguy
                          ratedrguy @wmarcio last edited by ratedrguy
                          @wmarcio said in My Console Themed Overlays for Retroarch:
                          Having the same issue. I believe the resolution on these are too high and have to be downscaled.
                          • wmarcio
                            wmarcio @ratedrguy last edited by wmarcio
                            @ratedrguy said in My Console Themed Overlays for Retroarch:
                            Exactly ... I had some free time and decided to take a look, the images are in 2560x1440, must be 1920x1080. I'm too lazy to do that now, if anyone does, please share the resized files.
                            Original size:
                            Thxs.
                            • sad_muso
                              @wmarcio Nice one! Tried a Genesis one as a test and good news is it works at 1920 X 1080! Bad news is, there's frame rate drop on Genesis. I'm on a Pi 3B. Is there a way around this?
                              • sad_muso
                                sad_muso @sad_muso last edited by
                                @sad_muso It actually seems to be a combination of overlay plus crt-pi-curvature shader. Guessing that shaders are the biggest overhead 😞
                                Clyde 1 Reply Last reply Reply Quote 0
                                • Clyde
                                  Clyde @sad_muso last edited by
                                  @sad_muso There are, but it also depends of the shader itself. Did you try @ghogan42's "zfast" shaders? They should be notably faster than the "crt-pi-curvature" shaders. There are also curved ones among them (one normal, one vertical) that I'm using togehter with overlays myself.
                                  https://retropie.org.uk/forum/topic/13356/new-crt-lcd-shaders-for-rpi3-they-run-at-60fps-at-higher-resolutions-and-are-configurable
                                  https://github.com/ghogan42/common-shaders/tree/zfast_shaders
                                  • Orionsangel
                                    Orionsangel @Clyde last edited by
                                    @Clyde Yes, I'm currently working on that with someone else. Hope to get them all up there soon.
                                    Clyde 1 Reply Last reply Reply Quote 2
                                    • Clyde
                                      @Orionsangel Great! I'm looking forward to that. 👍
                                      • Orionsangel
                                        Here's a link to download all to my Retroarch bezels so far.
                                        https://bit.ly/2Lvq9VI
                                        • Orionsangel
                                          These are bezels I made a while back for the first five Tomb Raider games on Playstation. I use them on Retroarch. They're now available in 1080p.
                                          You can download the 1080p bezels here - https://bit.ly/3bCuZuM
                                          • wmarcio
                                            wmarcio @Orionsangel last edited by
                                            @Orionsangel said in My Console Themed Overlays for Retroarch:
                                            Thank you, I admire your work. Are the images in this pack in 1080p?
                                            Orionsangel 1 Reply Last reply Reply Quote 1
