    My Hyperkin Duke Xbox One Controller is not detected by the system
    retropie 4.5hardwarecontrollerxpadpi4
    15 Posts 3 Posters 1.8k Views
    • Rhystic1R
      Rhystic1
      Hello! First time posting, so I apologise if there's anything I'm missing.
      I had a Raspberry Pi 3 for a while, and my Hyperkin Duke controller was working perfectly with RetroPie, even detecting it by its proper device name.
      A couple of days ago I decided to upgrade to a Raspberry Pi 4 mostly to speed up N64 emulation considering the new CPU and GPU capabilities of the devices which, while I understand they are still mostly untapped, I'm sure they will be exploited quite soon.
      Unfortunately, my controller is simply not working anymore: when the system boots I can feel the controller vibrating, but the OLED won't light up and the system just won't detect it properly.
      I can't remember if I had to change or install anything in particular to make it work with the previous Pi. I have Xpad installed. Any help would be much appreciated, and here are all the details:
      Pi Model or other hardware: Raspberry Pi 4 (4GB RAM)
      Power Supply used: Original PSU
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.5.19
      Built From: Manual installation following the official guide.
      USB Devices connected: Microsoft Keyboard; Microsoft Classic IntelliMouse; Hyperkin Duke Xbox One Controller
      Controller used: Hyperkin Duke Xbox One Controller
      Error messages received: None
      Log found in /dev/shm/runcommand.log (if relevant): N/A
      Guide used: N/A
      File: N/A
      Emulator: N/A
      Attachment of config files: N/A
      How to replicate the problem: 1) Plug in the controller on any USB port of the Raspberry Pi; 2) Boot the system: EmulationStation or Raspian itself will not detect the controller no matter which button is pressed.
      • quicksilverQ
        quicksilver
        Have you tried updating the xpad driver? Seems odd that it would work on your previous pi but not on the pi 4.
        • Rhystic1R
          Rhystic1
          Did you mean Xpad?
          I tried uninstalling it and reinstalling it both from the RetroPie-Setup and with the sudo apt-get install xpad command, but it just won't work. I even tried installing xboxdrv with no effect (I uninstalled it afterwards).
          • quicksilverQ
            quicksilver @Rhystic1
            @Rhystic1 Yes, xpad sorry, autocorrect. Xboxdrv shouldnt be needed. A googling of your issue I see others have had issues with this controller being recognized properly in linux. Something to do with the device Id not being recognized by xpad.
              Run the following command and post the output here in the topic:
              cat /proc/bus/input/devices
              This way we can check if xpad should recognize the driver or not.
              Rhystic1R 1 Reply Last reply Reply Quote 0
              • Rhystic1R
                Rhystic1 @mitu
                @mitu said in My Hyperkin Duke Xbox One Controller is not detected by the system:
                It seems like it's not appearing there:
                I: Bus=0003 Vendor=045e Product=07f8 Version=0111
                N: Name="Microsoft Wired Keyboard 600"
                P: Phys=usb-0000:01:00.0-1.4/input0
                S: Sysfs=/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:07F8.0001/input/input0
                U: Uniq=
                H: Handlers=sysrq kbd leds event0
                B: PROP=0
                B: EV=120013
                B: KEY=10000 7 ff9f207a c14057ff febeffdf ffefffff ffffffff fffffffe
                B: MSC=10
                B: LED=1f
                N: Name="Microsoft Wired Keyboard 600 Consumer Control"
                P: Phys=usb-0000:01:00.0-1.4/input1
                S: Sysfs=/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:07F8.0002/input/input1
                U: Uniq=
                H: Handlers=kbd event1
                B: PROP=0
                B: EV=1f
                B: KEY=300ff 0 0 0 0 483ffff 17aff32d bfd44446 0 0 1 130c73 b17c000 267bfa d9415fed 9e1680 4400 0 10000002
                B: REL=1040
                B: ABS=1 0
                B: MSC=10
                N: Name="Microsoft Wired Keyboard 600 System Control"
                S: Sysfs=/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:07F8.0002/input/input2
                U: Uniq=
                H: Handlers=kbd event2
                B: PROP=0
                B: EV=13
                B: KEY=c000 100000 0 0 0
                B: MSC=10
                  mitu Global Moderator @Rhystic1
                  @Rhystic1 said in My Hyperkin Duke Xbox One Controller is not detected by the system:
                  Probably that's why it's not detected. Try adding over_voltage=2 to your /boot/config.txt and reboot, then check again if it's detected.
                  • Rhystic1R
                    Rhystic1 @mitu
                    Hmm...I'm not sure I'd like to void my warranty and overclock the hardware just to get the controller working. Also, it was working perfectly on my Pi 3 without any overclock. Is there something else I can try?
                    mituM quicksilverQ 2 Replies Last reply Reply Quote 0
                      @Rhystic1 It's not overclocking, it's just adding more voltage to the USB port, just in case you're stumbling upon this issue.
                      Alternatively, try updating to the latest Linux kernel from Raspbian (sudo apt update && sudo apt -y upgrade), switch USB ports, disconnect the keyboard, plug/unplug the gamepad.
                      • Rhystic1R
                        Rhystic1 @mitu
                        I am already on the latest 5.4 Linux kernel. Running the commands had no effect.
                        Something interesting to note as well: if I plug in a standard Xbox One controller, it gets detected in EmuStation and the kernel, but I can't configure it: I get the "1 controller detected" but if I press any button nothing happens.
                        EDIT: command lsusb shows the controller, but without description (note that I have unplugged the keyboard and mouse, hence why they won't show):
                        Bus 001 Device 004: ID 2e24:0652
                        Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                          That's the latest beta kernel - did you have the same issue with the stable kernel ?
                          • Rhystic1R
                            Rhystic1 @mitu
                            On the Pi 4 I wouldn't know, as I upgraded to the beta kernel as soon as I started using it. On the Pi 3 I was on the stable kernel. If there is a way to downgrade without losing data I might do that to check whether the beta kernel is the cause of the problem.
                              You can downgrade to the current apt kernel with
                              sudo apt-get install --reinstall libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 raspberrypi-bootloader raspberrypi-kernel
                              You sholdn't be using rpi-update for regular updates. If you still want to do so, a backup is always advisable if you're not able to re-install/repair the system.
                              • quicksilverQ
                                For what it's worth, this alone will not void your warranty. The specific circumstances where the overclock bit is set are if force_turbo is set to 1 and any of the over_voltage_* options are set to a value > 0.
                                • Rhystic1R
                                  Rhystic1
                                  Quick update and some interesting details:
                                  Following
                                  , the controller is immediately recognized, though as a "Generic Xbox Pad". It works, but whenever I shutdown or reboot, I need to do this all over again. But what is strange is that I shouldn't need to be doing this at all: for one thing I never had to go through this workaround with my Pi 3, and second because the Xpad driver already has the device ID configured correctly and recognized as "Hyperkin Duke Xbox One Controller", but it seems that it's refusing to recognize it for me.
                                  So why is this happening?
