    Running-ROMs-from-a-USB-drive
    retropieusbrom directory
    3 Posts 2 Posters 378 Views
    • KrakatoaK
      Krakatoa
      Hi,
      I followed the guide Running-ROMs-from-a-USB-drive and moved all the roms to the USB drive. Now I am stuck. How do I delete the old roms of the SD Card now that /home/pi/RetroPie is mapped to the USB drive? I am sure there's an easy way, but I can't find any solutions after searching this forum. All I find is people saying delete the roms from this path /home/pi/RetroPie/roms, which wont work as it will delete them from the USB.
      thanks,
      https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
        mitu Global Moderator @Krakatoa
        @Krakatoa said in Running-ROMs-from-a-USB-drive:
        Remove the USB drive, reboot RetroPie, then delete the ROM files, keeping the folders intact. Insert the USB back and then restart EmulationStation, you should have your ROMs back.
        • KrakatoaK
          Krakatoa
          thanks, that did it.
