    PiShrink Help
    pishirnk sd
    7 Posts 3 Posters 232 Views
    • X
      xsy77
      Hi guys,
      New member, long time fan and reader.
      Is there any way to tell if an image has already been "pishrunk"?
      I have a new SD card that is 249GB but my build is 253GB and therefore doesn't fit.
      I have attempted to Pishrink however when completed, it says the final size is the same as the original. Now, I don't know if thats my error as its been a while since I have done this...
      Is there a way to tell if I already PiShrunk my Image?
        Post the full pishrink log, but if pishrink determined it cannot reduce your image further, it's irrelevant if it's been shrinked or not - it looks like there's nothing left to shrink.
        • X
          xsy77
          rootfs: 396808/15236672 files (0.7% non-contiguous), 60899202/61641112 blocks
          resize2fs 1.42.13 (17-May-2015)
          Resizing the filesystem on /dev/loop0 to 61637112 (4k) blocks.
          Begin pass 2 (max = 3798)
          Relocating blocks XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
          Begin pass 3 (max = 1882)
          Scanning inode table XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
          The filesystem on /dev/loop0 is now 61636608 (4k) blocks long.
          Shrunk Image.img from 236G to 236G
          So it says the img file is 236G however my mac shows it as 253GB in finder. Any ideas why?
          • quicksilverQ
            quicksilver @xsy77
            @xsy77 said in PiShrink Help:
            The file is actually the same size. What is happening is that some programs/OS see a megabyte as equal to 1000 bytes and other programs will recognize a megabyte as 1024 bytes. The amount of bytes is therefore the same but the amount of megabytes differ.
            • X
              xsy77
              Gotcha. Thanks.
              So this one cant be shrunk any further then? Any way you can think I can get this to fit on a 249GB card?
                If you don't delete something from it, it won't fit.
                • X
                  xsy77
                  Cool! Thanks all!
