    Best Snes Wireless controler 2020
    snes controllerwireless
    25 Posts 10 Posters 3.6k Views
    • F
      francis2019
      Hello
      There is discussion about wireless controler but nothing about SNES
      I want to know what is the best Snes Wireless controler for retropie.
      I was thinking about the 8bitDo, but I only see one review about a person using it with retropie, and its a bad review.
      Any one has used them on a retropie??
      • IanDaemonI
        IanDaemon
        I dig my 8bitdo SNES contoller.
        • Cocktail Cabinet Games
        • Check out the MAME RoW
        • DarksaviorD
          Darksavior @francis2019
          @francis2019 The only wireless snes controllers are from 8bitdo. I hate my sfc30 pad. Useless dpad. Looking at all the tape mods for just about every model, it looks like little was done to improve the dpad.
            mitu Global Moderator @Darksavior
            @Darksavior said in Best Snes Wireless controler 2020:
            Or the ones from Nintendo - if you can get them.
            saccublendaS 1 Reply Last reply Reply Quote 0
            • IanDaemonI
              IanDaemon
              @Darksavior You can use a lot of wireless controllers for SNES games, not just ones that replicate the look of the original gamepads.
              • DarksaviorD
                Darksavior @IanDaemon
                @IanDaemon I know, but op asked about snes. If it's any wireless controller, I recommend the ps4 one.
                • saccublendaS
                  saccublenda @mitu
                  @mitu Are these bluetooth? Would they work with retropie?
                  • RionR
                    Rion
                    Well if you want to go Wireless and don't want the hassle of Bluetooth input lag you could get a Classic controller to USB adapter - V3 from raphnet-tech and then buy a SN30 2.4G and SF30 2.4G for SNES and SFC Classic Edition from 8Bitdo.
                    FBNeo rom filtering
                    Mame2003 Arcade Bezels
                    Fba Arcade Bezels
                    Fba NeoGeo Bezels
                    • F
                      francis2019
                      ok so the only good options are the 8bit DTO who comes with a attachement for the classsic SNES and I need to buy a converter to convert the signal to a USB. like this one:
                      https://www.raphnet-tech.com/products/wusbmote_1player_adapter_v3/index.php
                      What other good options there is, with other controler type than SNES.
                      • F
                        francis2019
                        what about those:
                        any one has order them?
                        https://www.amazon.ca/Wireless-Controller-Classic-Gamepad-Receiver/dp/B07FCXL2VV/ref=sr_1_3?crid=5N65ZCMA9PL2&keywords=snes+wireless+controller&qid=1588073987&sprefix=snes+wirele%2Caps%2C160&sr=8-3
                          @francis2019 said in Best Snes Wireless controler 2020:
                          These are definitely not 'the best 2020 SNES wireless' controllers.
                          • PlayingKarrdeP
                            PlayingKarrde
                            What's wrong with the 8bitdo sfc30? I have been using it for a couple of years with no issues. I love it. Admittedly I use it with PC but feel no input lag, so if there is bluetooth lag it's on the pi's side, not the controller (yes I know bluetooth has inherent input lag but I'm very sensitive to lag and it's barely noticeable for me on PC).
                            IanDaemonI 1 Reply Last reply Reply Quote 0
                            • IanDaemonI
                              IanDaemon @PlayingKarrde
                              @PlayingKarrde I know there was a firmware update that improved input lag. Maybe the "bad reputation" is prior to the update.
                                From what I remember, the worst reputation was mainly for accidentally creating 'diagonals' with the D-Pad when pressing Up/Down or Left/Right.
                                They're ok, I have a SFC30 and it served me well.
                                • EcksE
                                  Ecks
                                  I use the SN30 Pro and SN30 Pro+ on my Pi when i am playing console games.
                                  • SPS
                                    SP
                                    I bought that nes pro 8bitdo controller around 5 years ago and hated it because most of the time it would not register when I pressed up+right. I had to press the buttons kinda hard for it to work or it would only register as up. So I just threw it in the box and forgot about it, and kept using my X1 controller.
                                    Fast forward to around february of this year. I was looking at a lot of youtube videos of the sn30 snes controller. All the videos that I saw were giving it great reviews and said there were no issues with the dpad. I figured, why not? It's been years since I bought the nes pro. So maybe the dpad is fixed. So I ordered one. I received it and I immediately tried it with Contra 3. The diagonals worked, but the down input is a little too sensitive. Whenever I lie down in the game, sometimes the character will randomly get up and walk left or right while I hold down on the dpad causing me to sometimes get killed by a bullet. It was enough to get me to go back to my X1 controller again.
                                    So for me the best snes controller to use is the Xbox one controller. To be honest, I thought I was gonna have problems with it due to the dpad being positioned at the lower left of the controller, but I have had absolutely no issues with it. The only reason I got the sn30 controller was because I loved the look of the DMG colored one. Oh, well.
                                    On the other hand, the M30 8bitdo Sega Genesis/Saturn controller is freaking great and I have no issues with the dpad.
                                    BOO!
                                    YAY!
                                    YAY! :)
                                    • PlayingKarrdeP
                                      PlayingKarrde
                                      That's too bad :( My daily driver is actually the SN30 pro+ and use it over all my other controllers (my previous go tos were the Switch Pro and the Xbox Elite). I don't have any dpad issues with mine although now I'm going to be scrutinizing it a lot more...
                                      DarksaviorD SPS 2 Replies Last reply Reply Quote 0
                                      • DarksaviorD
                                        Darksavior @PlayingKarrde
                                        @PlayingKarrde That's because they aren't using the old garbage dpad pcb design anymore that I noticed from a disassembly video.
                                        I mainly use real snes pads because I gave up looking.
                                        PlayingKarrdeP 1 Reply Last reply Reply Quote 0
                                        • PlayingKarrdeP
                                          PlayingKarrde @Darksavior
                                          @Darksavior Interesting. Good to know.
                                          In that case I recommend the SN30 pro+ as the best controller :)
                                          • DarksaviorD
                                            @PlayingKarrde I've been told I'm too critical, but then I see pictures of people doing the dpad tape mod on past models...
