    SNES controller not working properly on N64 emulator
    controllersnessnes controllern64 controllermcontroller map
    24 Posts 4 Posters 4.2k Views
    • L
      lupsyn
      I figure it out but is working only with mupen-64plus not with lr-mupen64plus-next. My controller is a snes clone kind of (as i specified in the beginning).
      From auto config it will be configured as :
      input_device = "usb gamepad           "
      input_driver = "udev"
      input_enable_hotkey_btn = "8"
      input_l_btn = "4"
      input_load_state_btn = "4"
      input_up_axis = "-1"
      input_left_axis = "-0"
      input_select_btn = "8"
      input_right_axis = "+0"
      input_r_btn = "5"
      input_save_state_btn = "5"
      input_y_btn = "3"
      input_x_btn = "0"
      input_menu_toggle_btn = "0"
      input_down_axis = "+1"
      input_start_btn = "9"
      input_exit_emulator_btn = "9"
      input_b_btn = "2"
      input_reset_btn = "2"
      input_a_btn = "1"
      (you can find this file in the dir : '/opt/retropie/configs/all/retroarch/autoconfig ' )
      Just gigging around i found this https://github.com/libretro/retroarch-joypad-autoconfig/tree/master/udev in which there are lot of configuration for lot of different joypads.
      I understood problem were into the x/y axis so i just appended these lines on the autoconfig file and everything start working :
      input_up_axis_label = "D-Pad Up"
      input_down_axis_label = "D-Pad Down"
      input_left_axis_label = "D-Pad Left"
      input_right_axis_label = "D-Pad Right"
      I think you can do the same from internal mapping for a single rom playing with the retroarch.cfg inside ...'retropie/configs/n64'
        mitu Global Moderator @lupsyn
        @lupsyn said in SNES controller not working properly on N64 emulator:
        These lines have no bearing on how the controller actually works, it just label the inputs so you can see them better in the RetroArch's configuration interface (instead of seeing the numbers associated). But if it works, that's fine.
        • L
          lupsyn @mitu
          @mitu yeah, reading some docs makes no sense. Maybe it's only working due i changed emulator. Thanks for helping anyway.
          • O
            omerfsen @lupsyn
            @lupsyn My Dpad keys (contoller is SNES ) are not working on Nintendo64. Can someone paste their \configs\n64\inputsautocfg.ini
