    Pi 4 Dynamic Marquee using secondary HDMI output
    pi4dynamic marquee
    26 Posts 22 Posters 12.9k Views
      Scrummel
      Has anyone had success with this yet. I would love to have a dynamic marquee set up with a single pi. Thank you in advance for any info and all of your hard work. This community is incredible.
      • designiconlineD
        designiconline
        omg that will be great
        • L
          losernator
          I have done that with rpi3+vga666 before now I did dynamic marquee with single rpi4.
          Same but pri4 is much easier because of extra hdmi port.
          It has done by RiNA from Korean raspigamer forum and I
          barely touched any ( just change port for rpi4)
          check out
          https://github.com/losernator/PieMarquee2
          and also
          https://github.com/rinalim/PieMarquee2
          F M 2 Replies Last reply Reply Quote 5
          • VickoV
            Vicko
            I don't know if this is what you were looking for, @Scrummel, but I was!
            Thank you very much @losernator ! This exactly what I wanted!
            By the way, what screen are you using for your marquee? Any info would be appreciated.
              Thorvald @Vicko
              I just finally got my Pi 4 and was highly disappointed to find out almost all of my marquees PNG flies throw and error when trying to view them, even with image viewer on the Pi OS desktop. Indicates they are corrupt but of course the work fine on Windows.
              I have mame 206 installed and am just getting the multi monitor support going to display the marquee on the second monitor while playing the game. It’s an easy trick where you use the artwork file to add a marquee section and force them to always be displayed on the second display.
              Attractmode always had support to display the marquee on the second monitor but I’ve only done it on Windows, will see how Linux handles it.
              That method above is nice thought! I’ll have a play with that as well.
              • F
                fuzznuzzbit @losernator
                @losernator Could you let us know what hardware you are using for the marquee display?
                WeirdHW N 2 Replies Last reply Reply Quote 0
                • WeirdHW
                  WeirdH @fuzznuzzbit
                  @fuzznuzzbit This might be an answer in another thread (haven't read it, though).
                  EDIT: Yes, it is.
                  • DorkVonWaterfallD
                    DorkVonWaterfall
                    Could be cool to merge this amazing project with this , I mean too use a ledpanel instead of lcdscreen:
                    01001110 01101111 01100010 01101111 01100100 01111001 00100000 01101011 01101110 01101111 01110111 01110011 00100000 01101001 01100000 01101101 00100000 01100001 00100000 01101100 01100101 01110011 01100010 01101001 01100001 01101110 00100001
                    • N
                      nat601 @fuzznuzzbit
                      @fuzznuzzbit I'm about to try this out using this display:
                      https://www.aliexpress.com/item/4000398514060.html?spm=a2g0o.productlist.0.0.2b2d711eAI8PUg&algo_pvid=e3a86007-72f9-402d-a3cd-852fad8314e8&algo_expid=e3a86007-72f9-402d-a3cd-852fad8314e8-2&btsid=0b0a187b15971846167752144e0b52&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                      It's going in a bartop with a tiny marquee, around 75mm height so this will fit perfectly. the resolution is 1920x480 so I'm going to have to create a bunch of marquees to fill the space, but it looks like it might do the trick, mini hdmi in and powered by microusb.
                        janderclander14 @nat601
                        @nat601 Did you got any success with that screen? I have the same one and I'm not able to display anything on it, even after setting custom timing settings in the config.txt file...
                          solrac21
                          @losernator awesome work on the pimarquee but I'm having an issue with pi4 and 1/3 1920 x 1080 lcd panel. I cannot get the marquees to fill the screen. They are cut off and I've tried resizing the marquees but nothing see to work....any ideas?
                            myboydash
                            I have just started using piemarquee2, its amazing! I'm
                            doing a custom build on a cab, and the only issue i seem to be having is I can't get piemarquee2 to associate with roms that aren't in my arcade folder. (Well, mostly. Ie... roms that reside in Atomiswave or Naomi) a couple roms will link to the instruction.png , or nothing at all. I'm trying to setup a marquee.png and instruction.png and its working for the roms in the arcade folder without issue. But not for the others and I'm not finding a way to make that happen. Cheers! Any advice is appreciated
                              myboydash @myboydash
                              So I've gotten a little headway, but think its dumb luck.
                              I've created a custom txt for each rom that isn't in my arcade folder.
                              One of them I've managed to get to show the marquee image and the instruction image. The others will only show whatever i put as the first line. And when I swapped the one that does work (as shown below) and put the marquee image first and instruction image second it didn't show both.
                              Ive tried each of these both ways and only this one shows both images.
                              /home/pi/PieMarquee2/marquee/instruction/mbaa.png
                              /home/pi/PieMarquee2/marquee/naomi/mbaa.png
                              • SgtJimmyRustlesS
                                SgtJimmyRustles
                                I've seen one of these really cool setups with Pixelcade
                                https://pixelcade.org/pi-install/
                                It's a really nice LCD marquee that does more of a pixelized marquees.
                                Check out /r/SBCGaming for Retropie, Recalbox, OGST (Odroid) talk and more!
                                http://www.reddit.com/r/sbcgaming
                                Hop on the Dicscord as well and chat about all things Retropie (or recalbox, lakka, etc)
                                https://discord.gg/JdXc6nx
                                Check out our Podcast!
                                  JZackMan
                                  I am having an overscan issue with black bars displaying bottom and top above my Marquee Image.
                                  query monitor displays:
                                  fbset -fb /dev/fb0 -g 1280 1024 1280 1024 8
                                  I am using the following hardware.
                                  Raspberry Pi 4
                                  Main Display 1280x1024 is standard 5:4
                                  Secondary 14.9" LCD Marquee
                                  HDMI+VGA+DVI Controller Board kit with 14.9inch LCD Screen LTA149B780F 1280x390
                                  What changes should I try to resolve my issue?
                                    JZackMan @JZackMan
                                    @JZackMan I found that the marquee images have to be resized to 1920X1080 to fill the screen.
                                    Here is my autostart.sh file:
                                    fbset -fb /dev/fb0 -g 1920 1080 1920 1080 16
                                    isdual=tvservice -l |grep "2 attached device" |wc -l
                                    if [[ $isdual == "1" ]]; then
                                    /usr/bin/python /home/pi/PieMarquee2/PieMarquee2/PieMarquee2.py &
                                    fi
                                    ##/home/pi/scripts/themerandom.sh
                                    emulationstation --no-splash auto
                                      dmmarti
                                      For those that run dual monitors on a Pi 4 .... @losernator has been updating his PieMarquee2 script with better refinements, etc.
                                      It's easy now to have a boot up intro video and default marquee video along with static game PNG marquees. His Github repo has all the information to add to any existing Pi 4 base RetroPie build.
                                      I'm in the process of building a new dual monitor arcade cab and found his new revisions a lot simpler to get setup with both PNG and MP4 files.
                                        majikill @losernator
                                        @losernator would it be possible to change the file paths to lead to the info scraped by skyscraper? most if not all users already downloaded these files, would be a tad redundant to have multiple copies of the same files. just a thought.
                                          darkmage
                                          Anyone know the format for Daphne to work? naming it rom.png or rom.jpg does not work since Daphne's folder setup is a bit different than most of the other systems. Thanks.
                                          • L
                                            losernator @darkmage
                                            @darkmage
                                            you can make symbolic link to scraped image path.
                                            eg: ln -s /opt/retropie/configs/all/emulationstation/nes /home/pi/PieMarquee2/marquee/nes
