Pi 4 Dynamic Marquee using secondary HDMI output
Hello,
I took an inspiration from PieMarquee2 and created a script which utilized Skyscraper cache for live marquees on the second display, so that you only need to scrape once and both the retropie and marquee will use the same data.
Also the omxiv-marquee was flickering on my cabinet, so I modified the mechanism a bit how the image data is transferred from the script to omxiv and it seems to work quite nicely now without killing and restarting the viewer.
If anyone is still interested in this (utilizing Skyscraper resources), please let me know and I can package these and write short instructions how to use - should these scripts work for you as well.
Thanks.
@petrisi i would love to use what you have please!
i have been trying to get the LCD panels working using a Adafruit RGB hat and failing...im no coder and only got a pi 2 months ago so its all new lots of errors but im learning!I have managed to get the great work by Losernator working on a second screen but the screens are expensive.
Having a RGB hat and 2 32x64 panels cost less that $50 :-)
https://www.adafruit.com/product/2345Im hoping someone on this forum can maybe add to the work Losernator has done and add support for the RGB Hat?
or even @losernator Losernator can chime in? :-)Im happy to put to work in if people can guide? ill even donate a rgb hat and screen?
thanks in advance for any help
Brit -
@britx
hey all...anyone willing to help get this working on a Pi3 with single HDMI and using a RGB matrix instead of the expensive LCD?I have been trying with no experience. Managed to get a gif playing on start but no im at a loss?
@losernator i read you had this working on a single HDMI? would you share the script please?
great work! also...... -
I’ve installed following the instructions - everything’s there - but no marquees show on the second monitor.
Can anyone tell me how i even begin to start troubleshooting?
My second screen is definitely working, i see loading screens - but just remains blank where there should be a marquee - i don’t even know where to start…
@losernator - I'm running into a few really strange things I can't figure out with the script. Hoping you can help.
I'm running a Pi4 on a 15.6" 1080P monitor with a VDSDISPLAY 14.9 for a marquee. I'm using the most recent script on your github.
Issue 1: When I run a rom - my main monitor displays a videoloadingscreen - the marquee changes from default.png to the marquee image. But when the videoloadingscreen ends and the rom boots - the marquee flashes back to default.png and then back to the marquee image.
Issue 2: Daphne, Dreamcast, OpenBor don't actually display marquee images for some reason. All the files are present in pi/PieMarquee2/marquee/ (appropriate folder) but they don't display at all - just stay on the default.png
Issue 3: When my marquee is plugged into the Pi4 - the command line text on my main monitor is vertically squished. I've tried both
fbset -fb /dev/fb0 -g 1280 720 1280 720 16
and
fbset -fb /dev/fb0 -g 1920 1080 1920 1080 16
in my autostart.sh - but neither make a difference.
Help? Anyone?
