    Controller Issue
    controller helpcontroller issu
    5 Posts 2 Posters 425 Views
      The_Rev
      Hi guys.
      I upgraded my 3b+ to 4.6 last night (from 4.4). Overall, good upgrade! I had some issues with one of my arcade sticks (madcatz SF2 stick) and tried to make some adjustments to controller settings.
      Right now I have one arcade stick plugged in and when I go into a game (e.g. SF2), every time I I add coins through the select button, it adds two at a time. Also, when I press the start button, it automatically starts two players and even though I have just one controller in, it acts like it is two connected controllers (e.g. I move right, both cursors move right, I hit a button, both hit the same button). I did try to set up a configuration file and I'm guessing I overwrote the original config file. I've tried switching the controller config to MAME 2003, but I still have this issue (although when I switch to Bad Dudes it doesn't happen).
      How do I reset my configurations to fix this problem?
      Thanks in advance!
        dankcushions Global Moderator @The_Rev
        @The_Rev please fill out all of https://retropie.org.uk/forum/topic/3/read-this-first
        i'm particularly interested in
        (run in 'verbose' mode via the runcommand before sourcing this, please)
          The_Rev
          Pi Model or other hardware: 3b+
          Power Supply used: Canakit 5v 2.5A
          RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.6 (installed on top of previous version, 4.4)
          Built From: RetroPie - original 4.4 from website install, this version was installed by choosing Update option in Raspberry Pi
          USB Devices connected: Mad Catz Chun Li Fight Stick (Xbox One variant)
          Controller used: see above
          Error messages received: No error messages
          Log found in /dev/shm/runcommand.log (if relevant): Tried running this after hitting F4 and going to the prompt (used "cat" and -v) and it says no such file or directory
          File: (File with issue - with FULL path) N/A
          Emulator: MAME
          Attachment of config files: How do I access the config files? Sorry, not seeing where to find it in the guide?
          How to replicate the problem: Pretty much, just push start on a game and it thinks the same controller is two controllers.
          Where else do I look and how can I share my config files? I don't know how to pull those and I'm not seeing the directions in the help file?
            @The_Rev said in Controller Issue:
            what exactly did you enter? you may find it easier to access via SFTP or SSH
              The_Rev
              Hi Dank. I just figured it out.
              I started Retroarch, went to settings --> input --> then looked at Input User 1 Binds and compared to Input User 2 Binds. Both had the same Controller (Mad Catz Chun Li Fight Stick) listed, so I pulled in a secondary controller and mapped it accordingly.
              The problem is solved. Now I have one other question I'll have to ask in the a new topic after I search more.
              Thanks!
              Rev
