    Naomi - 18 Wheeler Problem with Joystick.
    naomi18 wheeler
    9 Posts 9 Posters 2.5k Views
      Sid1968
      Hello,
      my system is a Raspberry Pi 4 with RetroPie 4.6.
      I use the "lr-flycast" emulator to run Naomi Roms.
      I haven't had any control problems in any naomi game so far. Only in "18 Wheeler: Amercian Pro Trucker (Deluxe, REV A)"can I not steer the vehicle left or right with my joystick. Before that in the game menu, for example when selecting the vehicles, I can very well turn left or right Select vehicles. The game dispays all the time
      The error message "MOTOR NETWORK ERR IN 01 OUT ff" is displayed repeatedly in the game.
      How can I configure the game so that I can control the truck?
      Cheers
      Sid1968
        T.Sap
        Having exact same problem if anyone has a solution.
        • KrakatoaK
          Krakatoa
          You have to map the analog control to digital then you can get trucking within the RGUI.
          When I first tried to set it up I was using the "analog to Digital Type, but that never worked. In the end I figured out you have to manually set it by the analog controls to the digital. In this case handle - and + See my pic below.
            skj @Sid1968
            @Sid1968 said in Naomi - 18 Wheeler Problem with Joystick.:
            Hello,
            Cheers
            Sid1968
            You need to get the romset 18wheelu.zip and run that . Controls are perfect and you dont get the motor network error
              scenarioL113 @Krakatoa
              @krakatoa Thanks Pal, this helped me out BIG TIME!!!
              CrushC 1 Reply Last reply Reply Quote 0
              • CrushC
                Crush @scenarioL113
                That version has the same trucks as the DC version though, kinda defeating the point of playing the NAOMI version.
                • sirhenrythe5thS
                  sirhenrythe5th @Crush
                  This post is deleted!
                  • H
                    harmeetsingh0013 @skj
                    @skj I am facing the same issue and currently using XBox controller. How can I fix that?
                      mitu Global Moderator @harmeetsingh0013
                      @harmeetsingh0013 Please don't bump very old topics. If you have an issue, open a new topic and add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
                      • mituM mitu locked this topic on
