    No sound with HDMI and Raspberry Pi 4
    sound problemblackscreen
    10 Posts 3 Posters 3.3k Views
      Antjac
      Hi,
      I'm trying to user Retropie with a Raspberry pi 4 / 4Gb and an old HD Ready (720p) TV.
      But, I've no sound with HDMI...
      I tried to follow some topics and I've added in /boot/config.txt but it gives a black screen after reboot
      hdmi_drive=2
      hdmi_force_hotplug=1
      hdmi_force_edid_audio=1
      When I've the blackscreen, here is dmesg :
      4.036371] vc4-drm soc:gpu: HDMI-A-1: EDID is invalid:
      [    4.036391] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036414] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036423] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036433] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036443] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036452] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036462] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      [    4.036471] 	[00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      What can I do ?
        Your TV has an empty EDID, which doesn't report which video resolutions are supported by it. Try adding in your config.txt:
        hdmi_drive=1
        hdmi_ignore_edid=0xa5000080
        hdmi_group=1
        hdmi_mode=7
          Antjac
          Try than starting from the lower end. Remove previous lines and add only
          hdmi_safe=1
          See if you get video/sound.
            Antjac
            Still black screen with just hdmi_safe (and all the hdmi_* added lines removed)
              mitu Global Moderator @Antjac
              @Antjac what HDMI cable are you using ? Is it the ones that's sold with the Pi4 or another cable model ?
                Antjac
                The HDMI cable sold with the box :
                https://www.amazon.fr/gp/product/B07WN3CHGH/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
                  BuZz administrators @Antjac
                  @Antjac which HDMI port? Use the one closest to power in.
                    Antjac @BuZz
                    @BuZz It's better, I've no blackscreen anymore but still no sound...
                      Try adding to your config
                      hdmi_drive=2
                      and make use the Audio menu in RetroPie to select HDMI as the sound output.
                        Antjac @Antjac
                        It's ok now, thank you :-)
