    Journey sound sample in mame2003-plus, solved
    samplesjourney
    86 Posts 7 Posters 16.5k Views
      mahoneyt944 @Lyle_JP
      @Lyle_JP we are using the official mono sound sample.
        mahoneyt944
        Twotigra could also benefit from this update.
          mahoneyt944
          @grant2258
          Hey I noticed the code for starting the journey sample was using pause in the if statement. Comparing this to current mame it does not. Is there any reason for the sample to pause after starting? I created a pull request to match it to current mame #807 but I wanted to make sure I wasn't over looking something? I figured this was probably left over from testing.
            grant2258 Banned @mahoneyt944
            @mahoneyt944 said in Journey sound sample in mame2003-plus, solved:
            the cod
            Well it woud just play if you didnt pause it. No big reason didnt look at any other code just saves doing is playing checks elsewhere change it whatever way you want it no other reason dindt use any other code for reference
              mahoneyt944 @grant2258
              @grant2258 ok thanks, I was adding support for other games and wanted to be sure it wasn't intentionally set that way for some reason I wasn't seeing.
                PhoenixFlood @mahoneyt944
                I’m late to this show. But my recent build of mame2003plus is still having issues with this audio sample.
                It works in the test menu, but in game it crashes. It also crashes when you I set the music to play in demo mode.
