    No audio at all - Solved
    audio
    20 Posts 6 Posters 15.2k Views
      CapNinja
      Pi Model or other hardware: oi 4 4gb
      Power Supply used: the original one
      RetroPie Version: 4.6 buster
      Controller used: 1 PlayStation 4 v2, 1 8bitdo sn30
      Hey guys, I hope you are well and safe. Can you please help me?
      I don't have any audio. In any emulator is port the results are all the same.
      Tried to execute some audio test, but still gets nothing. Any ideas?
        If you're using a HDMI TV, then make sure you connect it using the first HDMI port, the one next to the USB-C power port.
          CapNinja @mitu
          @mitu said in No audio at all:
          On the left, no video and audio. On the right, no sound.
          Then, tried the "sound issues" on https://github.com/RetroPie/RetroPie-Setup/wiki/Sound-Issues
          # forces HDMI mode
          hdmi_drive=2
          # Setting hdmi_force_hotplug to 1 pretends that the HDMI hotplug signal is asserted, so it appears that a HDMI display is attached. In other words, HDMI output mode will be used, even if no HDMI monitor is detected.
          hdmi_force_hotplug=1
          # Pretends all audio formats are supported by display, allowing passthrough of DTS/AC even when not reported as supported.
          # May not be needed for all HDMI devices
          hdmi_force_edid_audio=1
          My screen turned to 1/4 of normal size and I undid that choice instantly.
          I cannot find the link now, but I tried some "alsa test" who gave me nothing.
            Make sure you configure Audio over HDMI from the RetroPie menu and that you didn't accidentally muted/lowered the volume. Use alsamixer to change the volume/un-mute the sound and tgeb you can run speaker-test again to check if you have sound.
            • IceChes1I
              IceChes1
              Do you have a case on your pi? Take it off, it may be obstructing the HDMI connection.
              HOME CONSOLE
              Pi 4
              SanDisk 64 GB
              Master branch install
              3.5 amp CanaKit PSU
              Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
              HANDHELD
              Pi 0 W
              SanDisk 32 GB
              Random image I found. Had a driver I needed.
              IPEGA PG-9157 USB Receiver
                gorgar19
                I found that some TV's didn't have sound when I was working on my new build as well .tested it same cables no changes in any setting but 1 out of the 4 tv&s in my house had no sound . didn't look into the why because that's the tv that's mostly unused but is a good one to tweek my pie when everyone is home if that make sense.
                I'm sure someone here can give better answer then try a different tv and see if that makes a difference ,I know in my case that was the only difference between sound and no sound
                  CapNinja
                  @mitu nothing.
                  Audio card: default (when I change to HDMI, can't change system volume then. 0 is the value)
                  Audio device: pcm
                  omx video player device.
                    CapNinja @IceChes1
                    @IceChes1 I use the argon one since November/December with no problems, but I will test and post the results
                    @gorgar19 what amazes me most is the sudden problem. It was working fine before... I will try it too
                      Kinka-Byo @CapNinja
                      @CapNinja I have exactly the same problem in my rpi4, audio is reset to 0 each time I try to increase it. I think I have tried almost all hdmi audio fixes on the web...
                      The only difference is that It has never worked for me
                        @CapNinja can you run the following command and post the output ?
                        amixer scontents
                          CapNinja @mitu
                          Simple Mixer Control 'PCM' ,0
                          Capabilities: pvolume pvolume-joined pswitch pswitch-joined
                          Playback channels: mono
                          Limits: Playback -10239 - 400
                          Mono: Playback -132 [95%] [-1.32dB] [on]
                            So, it looks like your audio is not muted and the volume is up, so there's no configuration issue. Did you configure your Audio - from the RetroPie menu or through raspi-config - to output via HDMI ? Can you run the next command and post the output ?
                            amixer cget numid=3
                              CapNinja @mitu
                              numid=3, iface=MIXER,name='PCM Playback Route'
                              ;  type=INTEGER,access=rw-----,values=1,min=0,max=3,step=0
                              : values=0
                                It looks like you didn't set the audio ouput to be HDMI - either via raspi-config or via the Audio settings in Retropie. Can you try to set it to HDMI and then try a speaker test ?
                                  CapNinja @mitu
                                  @mitu how I did
                                  Advanced options > audio > force HDMI
                                  Then
                                  Start > sound settings > audio card > HDMI
                                  In sound settings, I can't change volume. It's 0
                                  After change the audio card to HDMI, I get the error "lv10: failed to attach default card"
                                  Did the test, still nothing.
                                  • KaK
                                    Ka
                                    Hi - I’m having the exact same problem right now. I’ve just put my Pi4 in an Argon One case, and am no longer getting any sound in RetroPie, in either the menus or in-game. The system volume in sound settings is at 0%, and every time I try to turn it up, it defaults back to zero as soon as go back into sound settings.
                                    It worked perfectly right up until I put it into the new case, which leads me to believe something isn’t connected properly. I’ll try taking it apart, and putting it back together again.
                                    EDIT: should probably say that I’m using RetroPie 4.6 on a Pi 4 4GB, with a 5v power supply and an 8bitdo SF30 pad.
                                    • KaK
                                      Ka
                                      OK, I’ve taken it apart and put it back together again, and the problem persists. Even more worryingly, if I take the Pi out of its case and just connect it directly to the TV, it’s still the same issue. Anyone got any idea what might resolve this please?
                                        mitu Global Moderator @Ka
                                        @Ka Are you using the first HDMI port to connect your TV to the Pi ? By default it's the only one that has audio enabled.
                                        KaK 1 Reply Last reply Reply Quote 1
                                        • KaK
                                          Ka @mitu
                                          @mitu that was it, I think - can’t believe it was something so simple. Thank you!
                                            CapNinja
                                            My problem was solved in the strangest way. Dust.
                                            Thanks to you all
