    How can I fix Retro Pie with graphical errors
    graphical errorretro pie 4.6raspbian stretcraspberry pi 3
    34 Posts 6 Posters 4.7k Views
    • H
      hackedmacbook111 Banned
      On raspberry pi 3 B+ I have graphical errors where images for emulators are missing this was after attempting to upgrade Retro Pie from 4.5 to 4.6 however on ssh it says raspbian stretch and Retro pi 4.6
      When I press start it shows a blank menu I would like to use my new USB sega genesis controller but the menu to configure is blank
      Anyone have an idea on how to fix this
        Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Can you show a screenshot of the error you receive ? What do you mean by 'images for emulators' ?
        • H
          I have Retro Pie 4.6
          Raspbian Stretch
          Raspberry Pi 3B+
          Solar Power Bank with 5v 2a USB
          • markyh444M
            markyh444 @hackedmacbook111
            @hackedmacbook111 said in How can I fix Retro Pie with graphical errors:
            Raspbian Stretch
            Raspberry Pi 3B+
            Power bank won't be providing a stable enough power source. Better to get a proper psu. I recommend the official Pi one
            Retropie in a PSX - Pi3
            • H
              I used a wall adapter 5v 3a and it still has graphical errors
                mitu Global Moderator @hackedmacbook111
                Can you post a picture or describe it in more detail - where do you press Start: in EmulationStation or after the game is started ?
                • H
                  This is on retropie and I press start with USB SNES controller in menu where all emulators located
                  • H
                    In Emulation Station
                      @hackedmacbook111 Can you post the EmulationStation's log file from \\retropie\configs\all\emulationstation\es_log.txt and the configuration file from \\retropie\configs\all\emulationstation\es_settings.cfg ?
                      Use pastebin.com to post them.
                      • H
                        Can I access this with ssh on Winscp
                        Or Ubuntu on Raspbery Pi 4
                        Raspbian on Retro Pie keeps crashing
                        I went into the setup script and updated
                        It fixed the start on emulation station but I still have graphical errors causing emulator pictures in emulation station to not display
                        I
                        • H
                          Also is there a way I can fix raspbian with the emulator ports on emulation Station menu
                          And also Save States
                          I recently got these problems after attempting to update Retro pi from 4.5 to 4.6
                          • H
                            The sd card that has Retro Pie on it is a premade sd card
                            Would it be easier to backup current sd card and make new copy of retro Pie on the sd card
                            • Thorr69T
                              Thorr69 @hackedmacbook111
                              You haven't stated where your SD card image came from. It may be the source of your problems.
                              Since you upgraded your 4.5 to 4.6 and are still on Stretch, you should really consider just rebuilding from scratch with a fresh 4.6 official image. (The new 4.6 distro uses Buster, not Stretch.)
                              RPi 3b
                              Official PSU
                              Official RetroPie image
                              Pandora's Box 5 controller
                              • H
                                Is there a way to upgrade raspbian stretch to buster with existing sd card
                                I don't want to backup if I don't have to I barely have enough space to store a 64GB backup of a 64GB Retro Pie sd card
                                Thorr69T mituM 2 Replies Last reply Reply Quote 0
                                • Thorr69T
                                  Look at you, still NOT answering the question where you got your original image...
                                  No, you cannot upgrade Stretch to Buster without starting over.
                                  RPi 3b
                                  Official PSU
                                    You could, but as I said beore, it's not recommended and - assuming the OS upgrade works - you might get issues later with your system.
                                    • H
                                      I bought a premade retro Pie sad card back in March
                                      • Thorr69T
                                        There we go. Game over. Third party images are not supported.
                                        RPi 3b
                                        Official PSU
                                          @hackedmacbook111 Yeah, figures. We don't support 3rd party images and selling RetroPie preloaded is against the project's license.
                                          Go ask the vendor for support - if you want support here in the forums, please install the image from retropie.org.uk/download.
                                          markyh444M H 2 Replies Last reply Reply Quote 0
                                          • H
                                            Is there a way to downgrade Retro Pie 4.6 back to 4.5
