    How can I fix Retro Pie with graphical errors
    graphical errorretro pie 4.6raspbian stretcraspberry pi 3
    34 Posts 6 Posters 5.3k Views
    • markyh444M
      markyh444 @mitu
      @hackedmacbook111
      @mitu said in How can I fix Retro Pie with graphical errors:
      @hackedmacbook111 Yeah, figures. We don't support 3rd party images and selling RetroPie preloaded is against the project's license.
      Go ask the vendor for support - if you want support here in the forums, please install the image from retropie.org.uk/download.
      Unsupported. Please reinstall the official image or ask the person you bought it from
      Retropie in a PSX - Pi3
      • H
        hackedmacbook111 Banned
        what can be loaded from a USB drive
        • markyh444M
          markyh444 @hackedmacbook111
          @hackedmacbook111 Please see above. Reinstall from the official image and you'll get some assistance in the forums.
          • H
            I want to use a 16 GB Sd card with 32GB USB drive as replacement for 64GB sd card that was premade
            Would I be able to have saves and roms on USB drive
            and have os and emulators on sad card
            • markyh444M
              @hackedmacbook111 all of this info is the documentation. Please go back, read the info for first setup and how to run ROMs etc from USB and see how you get on. Then come and ask for some help. Most of what you ask will have been covered in the docs.
              • H
                Could you link it
                markyh444M 1 Reply Last reply Reply Quote -1
                • markyh444M
                  @hackedmacbook111 retropie.org.uk
                  • H
                    I still can't find section on USB loading
                    quicksilverQ 1 Reply Last reply Reply Quote -1
                    • quicksilverQ
                      quicksilver @hackedmacbook111
                      @hackedmacbook111 https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/
                      Edit: I see now you are using an unsupported image, you should start over with the official image and you won't have these problems.
                      • H
                        Thanks this will help
                        • H
                          hackedmacbook111 Banned @mitu
                          I contacted the develper of the premade sd card they said they installed retro Pie with raspbian stretch
                          They now sell retro pie preloaded with games with retro pie 4.6 and raspbian buster
                          • H
                            What would happen if I flashed backup to sd card and put it into raspberry pi
                              dankcushions Global Moderator @hackedmacbook111
                              @hackedmacbook111 this is all we support: https://retropie.org.uk/docs/First-Installation/
                              • H
                                Go to new fourm called Retro Pie Backup to new sd card
