    Problem boot Retropie 4.6 on Pi4
    retropie 4.6boot problempi4
    8 Posts 2 Posters 801 Views
      Rulid
      Hi everyone,
      i have a problem with starting Retropie 4.6 on Pi4. I created the bootable sd (formatted in fat32) with win32disk imager but after inserting it into the pi4 and after completing the installation only a black screen appears (I also had to edit the config.txt file to force the hdmi output because there was no video signal). Can someone help me? Thanks in advance.
      Pi model: Raspberry Pi4 4gb
      official Retropie 4.6 pre made sd image from retropie website
      Micro Sd samsung evo plus 128 gb (I also tried with an 8 gb sd)
      Labists charger for pi4
      no error message during installation
        Can you post your config.txt ? You didn't mention what TV model/vendor you have problems with. Which microHDMI port are you using ?
          Rulid @mitu
          @mitu Tv model is Sharp aquos HD lcd 32". I changed the config.txt file by deleting "#" before "hdmi_safe=1" , "hdmi_force_hotplug=1" , "config_hdmi_boost=4" and in this way i solved the problem of no signal on the tv. I tried with both hdmi ports and nothing changed. I add that the installation of Raspbian (always with the modified config.txt file) is successful and installing retropie via terminal works. However I would like to install only retropie. This is the config.txt :
          For more options and information see
          http://rpf.io/configtxt
          Some settings may impact device functionality. See link above for details
          uncomment if you get no picture on HDMI for a default "safe" mode
          hdmi_safe=1
          uncomment this if your display has a black border of unused pixels visible
          and your display can output without overscan
          #disable_overscan=1
          uncomment the following to adjust overscan. Use positive numbers if console
          goes off screen, and negative if there is too much border
          #overscan_left=16
          #overscan_right=16
          #overscan_top=16
          #overscan_bottom=16
          uncomment to force a console size. By default it will be display's size minus
          overscan.
          #framebuffer_width=1280
          #framebuffer_height=720
          uncomment if hdmi display is not detected and composite is being output
          uncomment to force a specific HDMI mode (this will force VGA)
          #hdmi_group=1
          #hdmi_mode=1
          uncomment to force a HDMI mode rather than DVI. This can make audio work in
          DMT (computer monitor) modes
          #hdmi_drive=2
          uncomment to increase signal to HDMI, if you have interference, blanking, or
          no display
          config_hdmi_boost=4
          uncomment for composite PAL
          #sdtv_mode=2
          #arm_freq=800
          Uncomment some or all of these to enable the optional hardware interfaces
          #dtparam=i2c_arm=on
          #dtparam=i2s=on
          #dtparam=spi=on
          Uncomment this to enable infrared communication.
          Additional overlays and parameters are documented /boot/overlays/README
          Enable audio (loads snd_bcm2835)
          dtparam=audio=on
          [pi4]
          Enable DRM VC4 V3D driver on top of the dispmanx display stack
          dtoverlay=vc4-fkms-v3d
          max_framebuffers=2
          [all]
          #dtoverlay=vc4-fkms-v3d
          overscan_scale=1
            mitu Global Moderator @Rulid
            @Rulid said in Problem boot Retropie 4.6 on Pi4:
            I was hoping for the actual model, to know what video resolution is supports. Try to force 1080 by adding
            hdmi_group=1
            hdmi_mode=16
            to your config.txt and removing hdmi_safe. Are you using the 'official' HDMI cable from the Raspberry Pi store or the Labist kit comes with a different cable ?
            R 2 Replies Last reply Reply Quote 1
              Rulid @mitu
              perfect ! everything works now! eliminating hdmi_safe and entering hdmi_group = 1
              hdmi_mode = 16 everything works. Thanks so much ! you were really great!
                Rulid @mitu
                @mitu hello mitu, sorry for bothering you again. I would like to ask you for help again. by entering the commands you told me last time, the system started. However now the games do not start from the main menu. I am attaching a video for clarity (I know this is an unofficial image but I hope you can help me anyway. Otherwise I thank you all the same). video
                mituM 1 Reply Last reply Reply Quote -1
                  You said in your first post that:
                  Now you say:
                  If it's a 3rd party image, there's no but I hope that.... We don't support 3rd party images, ask the author for support.
                    Rulid
                    yes, with the official image it works after your help. Now i have a similar problem (with an unofficial image) and i was hoping you could help me. Sorry for the inconvenience, thanks anyway.
