    Mortal Kombat 2/3/UMK3 Audio
    76 Posts 13 Posters 39.4k Views
      dankcushions Global Moderator @GreenHawk84
      @GreenHawk84 i don't think any of that stuff works on lr-imame4all i'm afraid.
      GreenHawk84G 1 Reply Last reply Reply Quote 0
      • GreenHawk84G
        GreenHawk84 @dankcushions
        @dankcushions, so is there no way to access the service menu in mame4all?
          @GreenHawk84 that's what i said...
          • GreenHawk84G
            GreenHawk84
            @dankcushions , I see you have made discoveries recently regarding this issue. Awesome, so glad you continue to investigate. I wish I could buy you a beer !
            • GreenHawk84G
              GreenHawk84
              @dankcushions , I see you updated both MK3 and UMK3 in the Mame2003 compatibility list. These had poor audio for me as well, but I will go back in and play them extensively and report back.
                @GreenHawk84 said in Mortal Kombat 2/3/UMK3 Audio:
                i didn't... i had them all as 'has issues' someone seems to have turned both to 'ok' on the pi3, despite the issue log linked in the notes.
                i've now reverted the all back to 'has issues'
                • GreenHawk84G
                  GreenHawk84
                  @dankcushions , okay, that's what sucks about those lists, they are wide open for editing. I think known confirmed issues should be somehow locked until an admin has confirmed the fix. I also added a similar note to Rampage: World Tour.
                    that was supposed to be what's good about these sheets :)
                    however i've noticed the mame2003 sheet is completely screwed again despite all the editing rules i put on it. people can't be trusted so i'm reverting the last week or so and making it read only.
                    • GreenHawk84G
                      GreenHawk84
                      Just wanted to add a note here that MK2 on Mame2003 does not play the coin sounds at the start screen, only the continue screen. A very small detail but Mame4All plays the sound and it is based on and older romset.
                      • GreenHawk84G
                        GreenHawk84
                        Every once in a while I go back to MK2 and MK3 to see if any updates helped it, but to no avail. I hope one day my fav. games will be OK again. :(
                        • GreenHawk84G
                          GreenHawk84
                          @dankcushions, Anything new on this topic? If not that's fine, I was just curious.
                            darkmenace
                            Anything new to report? This sound issue is so frustrating. Other than that, the games run awesome and I love the MK series.
                              it's a shame there's this issue :( i'll update here and the github issue if there's anything to report. i tried an earlier version of lr-mame2003 but that first version i could compile on my mac (my dev environment) had the issue already. maybe i could port an even earlier version to mac but that's a pain.
                              basically nothing will happen with this issue unless you can find someone who knows C & audio programming well. i've done all i can :(
                                darkmenace
                                I note you said in your earlier post above dankcushions that you could increase the DCS_BUFFER_SIZE to at least delay the onset of the crackling audio.
                                You said you went from 4096 bytes to 8192 bytes. Have you tried pushing that to 16384 bytes or even higher?
                                Are you able to tell me how I can change this option in retropie on my Rpi3? Even if you can point me in the direction of the relevant config file, I can locate and edit the setting and do some testing.
                                Cheers
                                DM
                                  dankcushions Global Moderator @darkmenace
                                  @darkmenace i replied to your other thread :) https://retropie.org.uk/forum/topic/7084/mame2003-audio-crackling-mortal-kombat-games/2
                                    Melvin.FoX
                                    So still no luck with this one? I thought what will happen when lowering the buffer size?
                                      dankcushions Global Moderator @Melvin.FoX
                                      @Melvin.FoX makes problem happen faster
                                        Melvin.FoX @dankcushions
                                        @dankcushions but also disappear faster ;) but i don't know what will happen to desync. I read that changing the audio latency to 200 ms solves the problem somehow. Have you tried it?
                                          @Melvin.FoX this won't help. it will get worse and worse and get out of sync. i'm not going to fiddle with this any more than i already have. it should be a simple fix not a hack like this. the source code is available if you want to play!
                                            @dankcushions I am not programmer so I won't do much with it.
                                            What I did was raising audio latency to 200 ms and it gets totally out of sync (it's too much difference and it won't help with the issue at all). I just have to find other mame version that it works better. With mame2010 it just works choppy and mk3 has some serious slowdowns. Darn :/
