    Mortal Kombat 2/3/UMK3 Audio
    76 Posts 13 Posters 43.5k Views
    • GreenHawk84G
      GreenHawk84
      Glad to see this topic still has life. I am convinced that Mame2003 has this issue inherently coded into it, only to be ironed out over the years. The problem is the later versions of Mame such as 2010-2014 require more power to run these games properly. I am afraid we may just hit a wall until Raspberry Pi 4 comes out. Unless some dedicated work can be done with Mame2003 to fix our beloved Kombat titles.
        dankcushions Global Moderator @GreenHawk84
        @GreenHawk84 it's not a problem with mame2003 - if you run standalone mame2003 (mame 0.78) in windows you don't get this issue. the issue must be to do with the libretro implementation.
        but this topic doesn't have life until someone gets coding :)
        GreenHawk84G 1 Reply Last reply Reply Quote 0
        • GreenHawk84G
          GreenHawk84 @dankcushions
          @dankcushions yes I do remember reading that, my bad, I twisted it on accident. I wonder if the guys over a Libretro have a thread for this?
            G-Member
            I follow this threat to, MK3 or MK4 isn't running at all..... can play it on the N64 though but Arcade is so much better LOL
            • F
              FreshmanClasspi
              I'm totally new this but i've added the mk roms and the only one that works is the original mk.....any help on getting mk2-3 to even play at all? i'm using Pi 3 and mame4all.... or am I going about this all wrong?
              AlexMurphyA F 2 Replies Last reply Reply Quote 0
              • AlexMurphyA
                AlexMurphy Banned @FreshmanClasspi
                @FreshmanClasspi First off don't use Mame4All. That's best suited to a Pi Zero. What ROMSET are you using?
                • F
                  FreshmanClasspi @FreshmanClasspi
                  @FreshmanClasspi nvm....i switched over to lm-mame2003 and it worked
                  • GreenHawk84G
                    GreenHawk84
                    MK2/UMK3 still have the sound issue. :(
                    I raised the bounty to get it fixed.
                    • GreenHawk84G
                      GreenHawk84
                      I vote that we (since I contributed to the donations) give the money to the person who could also get it working on FBAlpha. If we confirm a fully functioning and proper MK series on FBA, that person should get the money. Not sure if anyone agrees, just my suggestion.
                        https://www.bountysource.com/issues/36272753-dcs-games-mk2-etc-slowly-overflow-the-buffer-periodically-distorting-sound
                        looks like someone has started working on this :D
                        i will test it as soon as it's completed and make sure it gets accepted promptly.
                        • GreenHawk84G
                          @dankcushions said in Mortal Kombat 2/3/UMK3 Audio:
                          I will test toooooo, I hope it works well!
                            this is now merged! if you rebuild lr-mame2003 from source (takes about 30 minutes) you will have it. can anyone test, please? i played mk2 for 10 minutes and got no distortion, but I didn't have a chance to test longer/other games.
                            GreenHawk84G 1 Reply Last reply Reply Quote 1
                            • GreenHawk84G
                              GreenHawk84
                              I am at work today but I will get home and test MK2, MK3, UMK3, and I THINK Rampage WT did it too so I'll check 'em and post my results. Probably extensive play to make sure this is squashed.
                              • GreenHawk84G
                                How do I do this, I never did this?
                                  @greenhawk84 said in Mortal Kombat 2/3/UMK3 Audio:
                                  https://github.com/retropie/retropie-setup/wiki/updating-retropie#updatinginstalling-individual-packages
                                  manage packages > main > lr-mame2003 > source
                                  • GreenHawk84G
                                    GreenHawk84
                                    Eureka! It works!
                                    • lostlessL
                                      lostless
                                      Has the binary been updated in retropie with this fix yet?
                                        darkmenace
                                        Is it normal, when going into update the lr-mame2003 via source to get a black and white command prompt style screen full of garbage continually scrolling?
                                        • lostlessL
                                          lostless @darkmenace
                                          @darkmenace yes
                                            darkmenace
                                            Whilst I think things improved a bit with the sound, I was still getting a bit of crackling and crustyness. Is there any easy way for me to verify that I successfully updated lr-mame2003 package to the version with the fixed audio?
                                            dankcushionsD GreenHawk84G 2 Replies Last reply Reply Quote 0
